Oxygen Sensor Discontinued
aa1a
I need the upstream O2 sensor for my 4runner. I can't find the right one. Toyota says it is discontinued. It is a 99 V6 4wd With California emissions. The problem is it is a 5 speed. The wire pigtail is 24 inches long. None of the aftermarket sensors have the long pigtail. Has anyone else had this problem? Any suggestions? Thanks, Jim
yup, discontinued by Toyota, but Denso still makes them.
You can call denso and tell them the part you're looking for, and order it straight from them (closest to OEM quality)
Or you can just go to your local auto parts store and ask for the upstream O2 sensor, and they'll have a denso one for you, but i've heard the quality isn't as good as the OEM denso ones. FWIW, this is the route I went.
DENSO 2349003 along with NTK 24670 are listed on RockAuto as the upstream CA emissions MT AFR sensor. Worth a check.
-Charlie
-Charlie
I pulled my replacements from Denso Rock Auto.. Granted Federal Emissions instead of CA.. Zero issues for many years now. :-)
erinobr2000
