Urban Runner Front Seat Repair How-To
NWSKIUrbanRunner
UrbanRunner Front Seat Repair How-To
So I too own a 2008 4Runner Urban Runner and of course the dang front seat cracked and wore out. I ended up ordering the seat cover part# 7107235281B0 from OEM Parts running around $338.00. With shipping it came to about $380.00.
So this is what it looked like when I started, cracked, ugly and basically an eyesore
After bringing it inside the house first steps were to place the seat on its side and remove the following screws located under and in the back of the seat which will remove the plastic housing. There are two of them on the bottom near the front of the seat. There are two more black screws at the back as well. You should be able to find them pretty easy :)
After that you will need a flat screw driver to pry the buttons off the seat to reach the two silver screws and remove those as well.
Next you will want to remove the black buttons holding down the seat. Don't worry these aren't super important so if you can't get them back in later, don't worry about it. Additionally the white tab you see holding the cover near the seat beat thing, just pop that out and set it aside.
After that begin to pry the plastic hold clips off the frame of the seat and work your way around you will see the seat come off the edges of the foam pad.
Next is the royal ***** part.
The white fabric part you can just cut with a utility knife but DO NOT CUT THE FOAM. Seeing you won't be using the old cover at all (unless you want to take it out back and shoot it with a 12 gauge for pissing you off :P)
After you are all done getting the old cover off it will look something like this.
Next you will want to pull the hooks out of the loops you see here on the seat. A good pair of needlenose pliers will help push them through. I know its a royal pain in the butt. Once you get them out, you will want to sand down any rust that may be on them (mine had some) and cut off one of the hooks with a Dremel to make it easier when you reassemble.
After you have completed that you will need to begin the process of putting the new seat cover on. You will want to first start with the back part with the hooks threading them through the fabric that goes down into the foam and the small rings. Having a second person will help to manipulate the foam while doing this. After you have gotten one rear section done, you will want to do the middle section, the other rear section and finally the front section
The rest is a snap (literally) push the seat cover back down and pull the foam from the back of the seat so that he foam cover is up snug against the bottom part of the frame. Snap the plastic snaps on the seat around the seat of the frame and reassemble the rest of the seat (screws, buttons, etc)
In the end you should have something looking like this :)
Hope this helps for others who have the same issue that I had.
Let me know if you have any questions.
Wanted to add a few items here
  • To prevent this from happening again, be sure to condition the leather parts of the seats every so often. The leather cracks when it loses all moisture and drys out. So conditioning the leather maybe once a month should help.
  • Another helpful item is seat covers, $30-50 for seat covers sure sounds a lot better to the pocketbook than dropping $400 or more on replacing the seat covers.
  • Try to prevent sliding in and out of the seat. Doing so will prevent from constantly stretching on the leather.
good description
thanks for taking the time to photo and document. Any reason you chose to re-cover the originals rather than adding a cover?
Reason why is I want the seats to still be in good condition someday when I go to sell the car. I'm still going to get myself some basic seat covers to cover the original seats to help preserve the seat from getting beat up or destroyed.
good job, i would add an extra layer a foam padding atleast 1/4 to 1/2 inch thick, it gives you more comfort. after having wet okole seat covers install over the stocks, its comfy with the extra foam padding.
2001ATL
