A.Wilson013
I can't get the aic to connect to my computer! I have the R4 software, radio shack serial to usb connector. Sometimes the R4 program will crash and other times with will do a count down and then throw me a retry message. I exchanged the connecter also and it still does not work on the second one. Anyone have any solutions?
All I can think is to make sure you're running R4 as administrator, and then make sure you have the correct port selected. Which windows version are you running?
A good way to check the port number if you're not too tech savvy is to take a USB device, like your phone, and plug it in to the usb port you want to use the USB/Serial adapter on.
Then hit the windows "start" button and type "device manager" and press enter.
In the screen, look at the "universal serial bus controllers" tab and find your phone.
Right click your phone, and hit properties.
On the "general" tab under "location" it should say something like "Location 0 (port_0005.Hub_#0001)".
Now disconnect your phone, plug your controller into that port (in this example it's #5) and it SHOULD work.
