So your saying I can input numbers on my map B in the 1-4 psi boost levels?
You can do whatever you need to to obtain the proper AFR, based on how you drive and what you're trying to obtain. Every truck seems to run a little differently and need different areas of improvement. Remember, it's unlikely it will ever feel as effortless as big Chevy V8 in my experience.
I have noticed that the 2.2 brings on boost so fast that the computer is not able to compensate fast enough from that initial part throttle to 1-2 maybe 3 psi in an instant, that is where hesitation happens at times.
We should also try and add some timing at the lower rpm to prevent low rpm ping high boost. I just got my truck figured out. (My wiring was installed incorrectly, My mistake). So I am now starting to figure out what other people were talking about.
Adding low rpm timing will make detonation worse not better.
Traditionally, you're totally correct. But I think he means "adding more retard" since that's how the URD 7th system works: the numbers you increase delays (or retards) the timing.
But good catch with both of you. Made me thing for a bit.
It's completely different the timing my 71 mustang.
Indeed. And for the record I did have to add quite a bit of retard on the lower end to combat knock. Only like 100' elevation and summers in the 90-100's so it got bad sometimes. Plus being a manual, I'd be at like 2,000 RPM in some gears to accelerate and 2-3K rpm seemed to need quite a bit of retard to stop be knocking.
Sucks, cuz you can feel the power difference, but at the price of NOT blowing up my motor, I'll take it. Never gonna be a race car.
E85 tune or meth injection. THen you could most likely add timing (removing retard) to get that power back and some.
On my DSM 91 pump gas I could run at most 20psi of boost and 14* max timing. After e85 I could run 36+psi and 22* max timing. Same car and setup. Pump gas dynoed 300whp, e85 400+whp.
I would like to get a tune for us 7th injector guys on e85. It's something I've through of for a while. But never really gone any further than the thought.
Could you mix 85 and 91 (generally speaking unknown of a ratio ATM ). Afr may go up a hair but octane would be higher.
Yes you can mix it. Its what the mazda/ford guys do with the direct injection fuel system since upgrading the system is pretty much out of question. So they do a 70/30 mix. You must do it perfect each time or you will need to retune. And yes you need a tune directly for the e85 mix as your car will run super lean at that ratio.
Its easier to just tune it for e85 if you car can handle it. Would need fuel pump and injectors that can handle roughly 30% more flow.
