USB issue on 2013 Limited
lenchikp
Hello,
Does anyone here have an issue playing music through flash drive on Limited T4R?
Same USB stick was used in 2012 SR5 T4R and played just fine, but for some reason on this vehicle, as soon as USB tab is selected from nav interface, music starts playing and then suddenly turns off. After that USB tab is grayed out, removing and re-inserting usb stick does not help :(:bash:
USB works just fine in my 2011 LE. I did have one USB key that failed after using it for a couple of months, but that was the USB key problem. Does your rig have entune or JBL? My LE has JBL. Have you used the USB key in another rig since trying it in the Limited?
Mine T4R has JBL, as oppose to SR5 (ENTUNE), where I have tested the flash drive.
No, I have not used the USB stick in another T$R, since I used it in mine.
I first had SR5 2012 for a few months and then Sandy has taken it:(
I purchased 2013 Limited and would assume USB functionality should work the same.
Most likely will have to make a trip to a dealer.
ghengiskhan
