Using Tacoma Fog Light Switch in 4Runner - Help/Advise/Pics On Hooking it Up
ts9790147
I have a 2006 Toyota 4Runner Sport Edition and looking to install some PIAA 520 ATP Auxiliary lights and wanted to use the following switch setup below to make it look as factory as possible
84160-04010 - Taco switch ($33.56)
90980-11090 - is the harness that clips to the switch that will hold the wire plugs ($2.47)
82998-12340 - wire plugs ($3.77/ea) 4 Req'd
I was wondering if anyone has done this mod and if they could provide some tips/ pics/ advice on doing this install.
Also does anyone have any diagrams on how to hook up auxiliary lights to this switch. Or does anyone have the diagram for which wire goes to which connection location.
This might help: Link it details which wires go where.
If you don't have your heart set on the taco switch, take a look at the FJ switch. They are a bit more but it has an on indicator and you can purchase the wiring/connector already assembled through Sparks toyota.
Link to pictures, purchase path and wiring diagram
