Jackkill1
Member
My opinion the PCV system is too important to save $10.00 on by reusing it.
I'll add this to my list of Spring maintenance task. Thanks to all who posted.
ok you convinced me, gonna order one for the next oil change.
Check out my old PCV valve and the problem I'm having...I believe it might be for lack of changing PCV... I would do a new one, not hard at all...need a 22mm wrench to unscrew it. http://www.toyota-4runner.org/4th-gen-t4rs/233449-need-help-water-oil.html#post2614829
Tried removing the old valve tonight, but it wouldn't budge and I was too worried to give it too much pressure.
Anyone else experience this?
Yes. I couldn't get mine out with a wrench. I ended up breaking the plastic elbow off and then used a deep well socket with a long breaker bar.
The title is pretty self explanatory, replacing the Positive Crankcase Ventilation valve on my 2004 V8 4Runner. This took maybe 5 minutes with the part and tools ready. This was the original valve too...yuck. I got the valve on Amazon for under ten bucks.
All you do is pull off the rubber hose and a small rubber shroud around the valve, set it aside. Use a wrench or pliers to loosen the old valve. Wipe off any residue around the hole, trying not to let any crud fall in. Next, screw in the new valve. I believe the torque specs are 20 ft/lbs torque. Replace the shroud, the hose, and bingo...that's it.
I did thread the new valve more than it looks. The only tool you need is a wrench or even some channel lock pliers. It was a little tough getting the old one off, but leverage helped. Anti seize may not be a bad idea for the new threads.
I ordered the same blue replacement as you from Amazon, but had some brown substance on the threads. How far did you thread the new valve in?
I feel like I could have kept turning it, but then the hose wouldn't have lined up, I got it to a little past the original position ('straight out'). Should I not go past there, back it out a bit? It was very hard to screw in as well...
