[MENTION=59542]Singtoe[/MENTION] , the a750 has a "sport" mode, how are you entering it, and what are you using to select the gear range?
This PDF has lots of cool info on the A750. See pg 39-41 for the multi-mode Auto info.
https://drive.google.com/file/d/0B-...k5Zi00N2ZmLWIxYTktYWU2YjkzZmU4MmYy/view?pli=1
It does not have this feature. It is column shift with push button od on the shifter. There is a separate switch to put it in to 1st gear but that is in the center counsel.
No Sport shifting tranny on this swap...
Oh.. Well that stinks.
Another question, how are you connecting the a750 to the 4runner shifter? The a750 uses a cable correct?
Nice work. Intrigued to see how you finish the CC swap from switched to resistance type beyond the clock spring. Keep the pictures coming. Also, are you running an extra wire to the spiral connector? Horn plus two CC wires- looks like you have four.
I'm planning to add a stereo remote to my '98 wheel and swapping to the later CC (from 3 wire set up to 2) will free up a much needed connection on the clock spring for the remote wiring. Subscribed!
The only problem you have is the ecu for the 4runner need 3 wire for the cruise to work. The tundra only need 2. For your swap to work, you would need to get some type of resistance translator to produce some type of a switched signal so the ECU can operate.
I had to use the 2 wire CC stalk because that is the signal the Tundra ECU needs to operate.
That's funny I just pm'd you seconds before your response. Yes I understand the diff between the two types but just curious how you actually achieve it!
Incidentally, the later 99+ T4R uses two wires also if that helps.
Did you run another wire to the clock spring or just 3?
Cheers man
Jame's 4runner is a 2000 and it is definitely 3 wires.
The Tundra is two wire, so I have one wire left over.
The 2001 and 2002 4runner is drive by wire and it might use a resistance type CC stalk but I did not look it up or research it.
Maybe that LBJ was over torqued?
Looks like progress is coming along well.
James must have a fat wallet.
From what I've heard, James is selling it after he gets it back.
:iagree: What he said!
I hope not James!
Well I must have been asleep or spent too much time working and not on the forum if Connor already knows that this project will be sold.
I guess the next logical answer would be why? Already have a buyer, and just acting as a broker?
