Many of us will be eager to follow this for sure.
What other engine swaps did you ponder? Curious if the 1uz entered the picture, and if so, why you ultimately decided upon the 2uz...
From what I remember, the 2uz is the more bullet-proof of the two, likely because of its full iron block. It has better torque specs also, so I imagine those might have been the reasons...
That said, a VVT 1uz has about the same torque (300+) as a non-VVT 2uz and weighs 200 pounds less. I just recall on my engine-swap wishlist from 2+ years ago I had the 1uz on top, but realize I might have missed a consideration such as pricing, availability, ease of install, etc...
EDIT/ADD - Some helpful info:
our factory V6
Toyota 3.4L 5VZ FE Engine Specs, Problems, Supercharger
1uz
Toyota 1UZ-FE Engine Specs, Reliability, Problems, Oil
2uz
Toyota 4.7L 2UZ-FE Engine Specs, Reliability, Oil | Tundra, LX 470 engine
Thanks for the links! I'll research those.
As far as the 2uz vs 1uz; it really started with finding a local 2uz for $500 with less than 1/2 the mileage of my current 5vz, and rolled downhill from there. It's hard to find weight comparisons, but what I did find seems to suggest a weight equivalency between the two?
As I researched further, I learned that the early 1uz is the bulletproof engine (overbuilt bottom end and rods) whereas after '93 the rods were made much narrower and end up being the failure point for the 1uz, 2uz, and 3uz engines if you start modifying them for more power.
I assumed that vvti would make the swap unnecessarily complicated, so I didn't look at those engines. :shrug:
Here's what I learned from the internet (mind you, I don't necessarily trust any of this until it is verified, but it was the best data I could find):
22re (2.4L) - 315-375 pounds, 105 hp, 136 lb/ft torque
5vz (3.4L) - 420 pounds, 193 hp, 220 lb/ft torque
1uz (pre '94) (4.0L) - 364 pounds, 259 hp, 260 lb/ft torque
2uz (4.7L) - <del>467 pounds</del>
582 POUNDS(see post 61), 230 hp, 302 lb/ft torque
3uz (4.3L) - 386(?) pounds, 282hp, 307 lb/ft torque
so based on that, and the availability of a cheap engine, I opted for the torque advantage and relative weight equivalency of the 2uz over the 1uz for the 3rd gen. (
and changed my mind when I weighed the 2uz.)
(however, I also found an early 1uz for my '93 minitruck :whip2: )
In retrospect, I think getting a new supercharger from Magnusson for the 5vz would be a far simpler, far less expensive, and ultimately more sensible choice. I'm looking at 500-600 for the conversion bellhousing (I'm 5spd) and $1800 for a ready-to-go custom harness before even getting into engine mounts (which I'll make), exhaust, radiator, fan conversion, A/C work, etc. Plus, I expect there will be a COG shift forward with the extra length of the V8 (wrong direction!) <- going 1uz would definitely help with this, though, for sure.
I'm still going to pick up the engine, though. :doh:
