Vacuume Hoses
PatrickStapler
So I was busy not finishing my VC gasket job today because I didn’t order the spark plug tube seals and I discovered I needed a few vacuum hoses. I have no idea what they are called or the part numbers, so it’s somewhat impossible to order new ones. Can probably just use 3/16” vacuum line on the first one. Any ideas on these?
Connects to Air Box an Metal tube on Lower Intake
Connects to Metal Tube on top of Upper Intake and rear of driver VC
Connects to same Metal Tube on top of Upper Intake and rear of Air Plenum at Throttle Body
[MENTION=176789]PatrickStapler[/MENTION]
https://partsouq.com/en/catalog/gen...hI$&vid=0&cid=&uid=262708&q=JT3HN87RXY0283787
you should be able to use this if you really wanted to order toyota vac lines.
I just went to my local parts store and grabbed like 5' of different sizes.. I think like 6,8,10,12 mm approximately.
Toyota
1734362110
HOSE, NO.3(FOR IDLE-UP)
maybe?
2382762030
1226162050
HOSE, AIR, NO.1
https://partsouq.com/en/catalog/genuine/unit?c=Toyota&ssd=%24HQwdckgWXEYRDhQ9LDcQHxZcQREOFCExSnp9DAJga20GWV1KBQsDFx4RV1VJX1sEBAUBBAMWGkkIGhAJFmNofQUOXilUdXhkb3lyFhpJAxBWEQ4MHhFCVUlfF0dfWEhMRl1SKx5bUVpQFwgCGBQNDB0QCRYEBQMHFEdHEFwRDhcDBAUOWFQ_EE5KanJjbXQ9MyNkAAdbBhI%24&vid=0&cid=&uid=262705&q=JT3HN87RXY0283787
that link is a good site, I have been able to locate parts that otherwise can only be found at the dealer. you have to dig around a bit and to me the parts diag. never really make sense? like why would you put heating and air conditioning for trucks with rear heater under electrical? because who knows I guess. anyway things are not always as they seem in the parts diagrams, and there is usually another one hiding under clamp or something stupid.
seltzernator
