Valve cover bolt
Chrizzouse
so yesterday I was doing my valve cover gaskets and as I was putting on and torquing the passenger side cover I sheared one of the bolts, now I have to extract the darn thing on my 99 t4r anyone know where online I can order these bolts from.
I don't think my torque wrench works properly because it never clicked and I have a good eye for torque and it was well over what it's supposed to be. So is it 14 or 53?
My bad yes 53 in lbs which you need an in lb torque wrench for. In ft lbs it's 4.5 ft lbs. I used a 1/4 drive and with my hand around the drive portion I turned it until it was pretty snug. Also used a little blue Loctite not the red stuff.
It should be sticking out the bottom. You may be able to get ahold of it like that. 4.5 foot pounds is correct.
ghengiskhan
