Fixed It.
Now the kicker was; the first thing we checked was the Starter Relay. Did several checks with the multimeter and 9v battery for both continuity and to hear it opening - and ALL checked good.
But after describing the symptoms a mechanic friend insisted it was the relay.
Jumped the starter relay and voila - it started, after almost 9 days of being unstartable.
Instead of paying the dealer price for a new starter relay and Autozone's $45, I went to the local Pick - n - Pull and got a used one for $7.
My recommendation to all those thinking unstartable is due to starter - jump the starter relay #3 and #5 pins in the fuse box, this will give you the automatic determination if the starter is good or its something else.
- The ignition switch must be in the ON position,
- Use ample thickness wire, I used 12gauge
- If it starts plug the old starter relay back into the fuse box.
