VERY Heavy Rear Coil
T4R120
Is there any coil/spring out there that is heavier than OME 899 spring rating, I believe the OME 899 are rated at 880lbs.
I got lots of load at the rear (bumper, spare tires, subwoofer, cabin, etc...) plus I also tow boat, trailer, etc...
Air Lift 1000. There when you need them, not when you don't.
That was going to be my point. If it is for towing... No reason to have a horrible over sprung suspension all the time. I don't think you realize how stiff those springs are. To want more is nuts. You need to buy a 1 ton truck if you are carrying that kind of weight in the back.
I have the 897's which are a shorter version of the 899's and I agree with the rest on using airbags for towing. 897's are borderline too stiff for even an additional 600+ lbs.
