Vibration at 60+ mph
Zadams31
I've had vibration at 60+ mph and when I let off gas I get small viberation as well. I have the general grabbers and have gone about 10k without balancing them has anyone else had this issue with them?? I had michelins and never had to balance them but they're an all road tire. I had differential service done last week everything was good there.
You definitely need to balance them...
Could also be drive shaft or pinion bearing. How thorough was the diff service? If they just checked/replaced fluids they may not have checked for bearing play. I had a small vibration on my '94 last week and it turned out to be a slightly loose pinion bearing. Snugged it up, restaked the nut, and it's fine now.
I had the same issue for the longest time. Thought it was the tires, bought new tires, same issue, balanced, always checked out right, until I was told I had a bad front wheel bearing. I had the 2 front wheel bearings changed from an independent Toyota shop and couldn't believe the night and day difference in how it drives. No more vibrations!
I replaced all the u joints and still have it! I will def check those wheel bearings I've never had to look at those before so it might be time.
have to second Ventil8's experience. my rig started vibrating at about 63-66 mph. had the front wheel bearing/hubs replaced and it is so solid now, couldn't believe the difference.
Cheers
Scott
Did you have your tire road forced balanced? Just balancing tires sometimes isn't enough. The road force puts a load on the tire to simulate weight and shows the amount of imbalance between the tire and rim. I have 32's and I road forced them, it was really high so I know I can expect some vibration above 65 and I do. Sometimes you can move the tire to a specific spot on the wheel and it'll bring it down but in my case they were to high. Only thing I could do is get new tires or wheels.
Had the tires balances that helped a little bit he said I had two tires a little out of balance. I'm close to a driveshaft place I'll see if my driveshaft is out of balance and U joints are all in good shape. They're all aftermarket and not OEM been down that road before with other parts not holding up well
I just helped a buddy fix this on his 5th gen. It was the drivers side wheel bearing. It was not easy to replace. It required a press and lots of skill to have it done right.
