I have a strange problem that I can't seem to find the answer to...
I have a 2007 4runner sport V6 - 150k. I had the rear diff replaced about 2 years ago.
Recently, I've been getting a low speed (rotation type) rumble from what sounds like the drivers side rear. This only happens around 5-15 mph - and goes away at any higher speeds. I don't feel anything in the steering wheel.. and tires are wearing normally. (I took the car back to Big-O for a rotation and I mentioned it to them)... they rotated the tires and found the rear diff to be slightly low - so it was topped off). The low speed rumble / vibration seemed to go away for about a week - but now its back.
I have read and read and read about every post here - and here's what I've done so far. Besides the rotation.... raised the rear end didn't find any 'play'. Drained the rear diff.. cleaned the plugs.. replaced with nearly 4 qts of Royal Purple. (Since I heard the "hiss" from the plug removal - I went ahead and removed the breather and ensured that is working too. Yet.. the low speed crap is still there.. its not loud.. just very low and sounds as if something is binding somewhere.
(Diff fluid was a little dark - but nothing really jumped out as being a problem)
Has anyone experienced this sort of issue? I've read posts about checking the U joints, etc.. but before I continue blindly.. I wanted to check with other members for suggestions?
HELP!
HELP!
