Vibration is driving me crazy!
Did the vibration start right after replacing the U-joints? Did you mark the alignment of the driveshaft and trans/transfer case before replacing them? Another thought if it's a V8 4x2, the driveshaft has a harmonic balancer pressed onto a rubber bushing, it can degrade far enough to cause vibration
- Does it stop if you let off the gas?
- Do you feel it through your steering wheel or seat?
- have you rotated the tires?
It goes away when I let off the gas. I feel it somewhat in the steering wheel and somewhat in the seat. It’s almost like I’m hitting a light rumble strip. Yes tires have been rotated
I had the vibration before I replaced the U joints. Yes I made sure to mark everything so that I put it back at the exact same place. I have the V8 With all time 4 x 4. Guessing it has a different set up without the harmonic balancer?
Look up some posts on the torque converter shudder. More than likely it has something to do with that rather than any other rotating assembly since it sounds like its load/rpm dependent rather that pure speed dependent.
I'm not sure how well they work, but there are additives advertised to reduce/stop torque converter/auto trans shudder.
Gotcha. The 4x4 doesn't have that harmonic balancer, it was put on the V8 to eliminate vibrations with the length of the 4x2 driveshaft. Guys with the V8 4x4 upgrade to the GX470 driveshaft because of a similar problem, but I think that was more closely aligned with a clunk coming to a full stop.
Is this a AWD? Do you have a lift?
if yes I would disconnect the front driveshaft and see if it still has a vibration, by what you're describing my best guess is something with a CV axle, I've had to return a new CV axle for vibration.
my mechanic told me to replace the brake hose, cause passenger front tire is not moving while on the lift. tomorrow Im going to replace the front brake hose, calipers and brake pads.
I was nerding out trying to learn about the lock-up on these, and found this. (I wondered if the transmission slips all the time to save fuel at the expense of friction material - I know what I would rather buy, fuel. It's easier to replace.)
Toyota Flex Lock Up Converter (A Rose by any other Name) - Transmission Digest
Not all flex-lock issues have TSBs or trouble codes to refer to, as is the case of a 2007 Tacoma equipped with an A750E 5 speed.
Initially, a customer had his Tacoma serviced with 86,000 miles on it. Unfortunately, the shop put in the wrong fluid. The vehicle required World Standard (WS) – and that’s no joke. Always use WS where required, or shudder could rear its ugly head. The customer returned the next day with a shudder that supposedly was not there previously. The shop flushed and refilled the unit with the proper fluid, but no cigar. The problem remained and the games were on.
Overall, the transmission worked well. All upshifts and downshifts were good and on target and if the vehicle was driven with a normal or heavy throttle, lock up worked good as well. The issue was light throttle take-offs.
Flex lock on this vehicle cannot start to apply until after a shift to second gear and normally not until 20 or 30 mph, which is where the Tacoma started “buckin, chuggin, shakin and shudderin”. It would actually buck like you were shifting a manual from 1st to 4th and then it would start to shudder.
A reflash of the vehicle’s ECM was useless and the correct reset (memory reset) needed to be done with a Toyota scan system, since most regular scanners are unable to do it. There were no trouble codes and all related sensors were tested and found to be functioning correctly. An engine systems check was also performed to look for firing issues such as spark plug, coil or injector problems. None were found.
At higher speeds (above 40 mph), lock up could be cancelled with the brake pedal. If you touched the pedal, the TCC unlocked because it was in full lock up, but below 40 mph, pressing the brake pedal had no effect.
To determine if the shudder issue is definitely due to flex lock, place the shifter in manual fourth. The transmission will shift 1st through 4th and lock up will only apply in 4th and only with full apply, no partial. If all is well, flex lock is the thing you’re dealing with, as it was on the Tacoma.
Flex-lock issues can be due to a bad converter, engine stumbles, ECM or sensor glitches or valve-body/solenoid wear problems (figure 4). The Tacoma had TCC valve wear that needed to be addressed. Fortunately, replacement valves and cutting tools are available in the aftermarket.
Let us know how you get on and if it solves the problem mate. :)
The brake hose was find! The front passenger caliper was frozen not letting the wheel move free.
Yesterday I drove 55min on the highway and no vibration.
I had power stop front brake kit. I replace the calipers and brake pads with power stop caliper and pads
Sent from my SM-G986U using Tapatalk
That's great I'm pleased it got diagnosed it was an easy fix for you!
not a easy fix as I was trying to pin down the vabration for almost 2 month.. I had 3 tire balance 2 of them with HUNTER ROAD FORCE and a set of new tires FALKEN WILDPEAK AT3.
DJNutshell
