Virginia: OME 886 AND Toytec Superflex 4th Gen
VT_Kook
Selling for $250 as a set. Need these gone asap. Willing to part them but you will pay more than just $125 a pop. They are hardly used as I literally put the superflexes on then sold the truck and returned to stock. the 886 have never been on the Truck. Shipping available on you
Hello,
I have two rear (x-reas) leaking. From what I am reading, I need to replace all 4 so the most cost effective solution is to just rip x-reas out and go aftermarket. Will these work for me in the front end?
Thanks,
Shaun
Hello,
Thanks,
Shaun
He's selling springs. XREAS is your shock setup, can get aftermarket (ie, bilstein's) and use with your factory springs. Of course, you can also swap out springs at the same time if you're lifting, etc.
In which case, you'll want to check the spring specs to determine if they'll suit your needs - the seller certainly doesn't know if they're appropriate for your specific build...
Cpn2mss
