Voltage problems?
dragon.burn
Hello,
I'm new to this whole forum thing, but I was hoping that I might be able to get some insight as to a problem I'm having with my 4runner from people more "mechanically incline" than myself...
I have a 1994 Toyota 4runner. I bought it used in 2004. Three months after I bought it, it blew the head gasket. I called Toyota to see if my 4runner fell under the recall, gave them my vin # and they said, "no go". So I paid to have it fixed on my own. I drove it without any major problems for about a year. Another recall came out regarding the steering column..? So it took it in and had it fixed. It's been leaking steering fluid like a sieve ever since. But that's not my main problem. About a year ago my clutch started slipping and instead of getting it fixed I parked it and used a back up car till I could come up with the money to pay to have the clutch replaced. So it sat... for about 9 months. I would run the engine for about 30 minutes every month to check and make sure things were keeping up. It did have a mouse nest in the engine compartment the last time I went to run it... :(
The meat: This last month I finally came up with the funds and when I went to start it it ran for only about 3 minutes and then died. It wouldn't turn over on it's own so I jumped it. It turned over and ran for another 3 minutes... and died again. I tried jumping it again but this time NOTHING. No power. No head light, no radio, no dash lights, nadda... :cry2: I had a friend come over and check it out and he made sure that the battery had a charge. Changed out a few blown fuses (irrelevant that I knew of, a windshield wiper fuse and something else small), cleaned the battery terminals and just poked around under hood in general. Waa-laa. It turned over and ran. I let it run for about 10 minutes then killed it. 3 days went by and I went to run it again and :rant: Ran for 3 minutes, died. But this time the lights still worked. The again I tried to turn it over and nothing. Then... nothing again. Now there is nothing working again. There is a charge in the battery, but for some reason it's not "getting to anything"...? I checked the fuses that we switched out last time and they all still look good...
I was thinking that maybe a mouse chewed through some wires and is causing a short? I really don't know squat about mechanics and would appreciate ANY help that anyone has to offer.
Thanks so much.
I've seen mice destroy wiring before, with erratic results. To see if that's the problem you're going to have to inspect it all the wiring closely.
Start by checking all the battery cables, both pos and neg. Make sure both ends are clean and tight. There are 3 neg/ground cables and the check the pos all the way to the alt.
