VOSLA +30 HIR2 Bulbs for 9006 replacement
lightfreak
Didn't see much discussion on these particular bulbs so here's some pics and info , I just received a pair from a local GM dealer for my '04 T4R.
They are supposed to be 30% brighter than regular HIR2 bulbs, but with reduced life. 300-500 hours on average. I think most HIR bulbs are around 800 hours
They are OEM on some GM vehicles, same power consumption as 9006's and won't piss off other drivers.
These bulbs are a cheap upgrade compared to other HIR and 9006 bulbs.
A comparison shot I found online from a RAV4 , Vosla +30 on the left, factory 9006 on the right:
9a736e5717862ee6ed0d4c41e19078a2.jpg~original
I got them from a local GM dealer in Canada for $20 CAD each. I've seen them online from US retailers for around $12.50 USD .
ACDELCO 23342527 Headlamp Bulb | RockAuto
CandlePower is selling them for $32/$28 USD each
<b>NEW</b> VOSLA HIR2 (9012) +30% "Super Bright Light"
Bulb Info
vosla - Automobile Lighting - Headlight Bulbs - Headlight Bulbs - Produkt: HIR2 · 30% more Light
http://www.vosla-german-lighting.com/upload/products/pdf/en/28432.pdf
GM Part# 23342527
VOSLA Part# 28432
ACDELCO Part # 23342527
All above part numbers refer to the same product.
They will have Vosla , +30 and "Made in Germany" printed on the bottom, with yellow o-ring and bottom cap.
IMG_9805_zps3zho0vcb.jpg~original
IMG_9806_zpsyyavocnb.jpg~original
IMG_9807_zpsr5wzqxlz.jpg~original
As with other HIR bulbs, one tab on the bulb will need to be trimmed to fit the headlight bulb holder.
It's very easy with simple tools, I was able to do one in just a few minutes.
Below pic shows the grey area you need to trim off, black area is what you will end up with after trimming
c0d4e837-9ace-4639-9f68-f42db37bc713_zpso5gpdvnt.jpg~original
I cut a small sticker to 8mm x 3mm dimensions and stuck it on the tab and used snippers to trim around it. Then just used a small flat file to finish it off.
Bulbs fit perfectly and snap into the holder just like the previous bulb
IMG_9798_zpsdjw3aea2.jpg~original
dee6cde8-75c9-46b5-aa06-c5a76a1faac3_zpsolahqixw.jpg~original
IMG_9803_zpsmbbgm6n3.jpg~original
I'll update this post later with night shots, need to my restore my headlights first.
Easy and affordable mod for brighter headlights!
If anything they should produce less heat as more energy is being converted to light.
2.5 year update:
Been so happy with them I put them in the fogs as well. For the price, it's good bang for the buck.
After 30 months of use the headlights bulbs died within a day of each other.
Have a spare set already modded ready to go.
matisgugle
