VSC and TRAC lights always on P430 error Im cool with it
bassmacka
Member
03 V8 4x4
So I first had an o2 sensor error and replaced all the o2 sensors., then I started getting this p430 catalytic converter error. I had the cats checked out by a muffler shop and they said it was fine so the p430 error is cosmetic and probbaly need sensor replaced.
The side efffect is that the vsc and trac are always off. Im actually fine with it because I consider both to be nanny systems that I have always been annoyed with not being able to shut off.
Is there any reason that I cant just continue like this. Im ok with them being off. VSC and TRAC will always be off by atrac will still kick in for offroad. ( havent tested just assuming)
Are you me? My 04 v6 4wd has the same code. CEL, vsc, and trac always on. Replaced an o2 sensor and didnt fix it. Guy said i could drive it, its just below efficiency. My gas mileage is the same. But that CEL is annoying. I might replace the cat just to make it go way
Yeah it is annoying, I was just wondering if there was any other bad sideffects of leaving it. i HATE VSC and TRAC , they can go straight to hell. So not having them is really nice. I dont have a way to turn them off on this rig
There is a mod to add in a switch to disable them. I'm in the same boat but trac comes in handy off road every once in awhile. I always thought it wouldn't help till I gave it a try.
For you, I would suggest looking at the simulator harness from URD. It tells the ECU the cats are working properly, which eliminates the codes. Again, the device is marketed off-road only, be aware.
You have P0420 and / or P0430 codes as well? Maybe a harness for you as well. Just to be clear, I have no connection with URD and their product may not fix everybody's cat issues (it just tells the ECU the cats are fine), but it has served me well for three years and if that helps somebody else, why not share my experience?
Best of luck guys!
Best of luck guys!
I do have those codes. I was talking about a switch you can add to disable the traction etc. you still need the urd harness to clear the check engine codes.
All you need are those spark plug defoulers. two come in a package, drill one out with a 1/2" bit and put the o2 sensor into that one and take the undrilled defouler and screw that on top of the first one. The small hole prevents large amounts of exhaust gas from getting to the o2 sensor. This works even without a catalytic converter installed. I have them on my truck, no CEL of any type and everything works great.
that's a solid idea. what does that cost?
Doesn’t always work. I have them on mine (installed by previous owner) and still have the P0420.
They do not work unless you use 2 of them for each 02 sensor. And the 02 sensors have to be denso or you are out of luck. I verified with Techstream live data that you can literally have NO catalytic converter installed and the computer still accepts the data as valid. Can you take a pic of your install, I would love to see what happened to make them not work.
Yeah I know about the doubled up spacers, and that is what is installed. They are both on just the driver’s side rear sensor (which is what the code is indicating is the bad side) I don’t know for sure that it is a Denso though. What is the best way to add photos on this forum? I used to use photobucket, but apparently they screw with the photos these days so I guess that’s no longer a good option.
I just use the paperclip attachment function like this:
