Bama Ho Runna
both my VSC off light and traction control lights are both on and i cant get them to cut off. i need traction control. if anyone knows how to fix this i would really appreciate it. comment or send me a pm. thanks!
Well on the 3rd gens, when the check engine light comes on, so do the vsc and trac lights. Its so you take it in and get it checked, really stupid concept.
Get that code cleared and the lights will turn off if its like the 3rd Gen.
Please refer to this thread to understand how the warning lamps function on your vehicle: http://www.toyota-4runner.org/4th-gen-t4rs/151487-check-engine-trac-vsc-read-me.html
We need codes to even begin guessing at what could be wrong with the vehicle, a MIL is akin to seeing a Grocery Store with a lit "Open" sign. You know the store is actually open, but you have no idea if what you need is inside until you check it out.
[MENTION=86849]Benjamn88[/MENTION] the newer Toyotas have a lot of ABS/VSC/Trac codes in their modules now, but many of the integrated systems like the 4Runner, FJ Cruiser, LandCruiser, and such have no diagnostic methodology to them besides "process of elimination" if you look at a couple of my threads with the keyword "Hydraboost" you'll see what I went through diagnosing my own brake master cylinder unit. The system is an "all-in-one" with a master cylinder, ABS solenoid pack, and accumulator pump & tank integrated into one unit. What's weird is there's 11pages in the FSM to tear the unit down and put it back together again, but Toyota has no diagnostics to test it and they just want to replace the entire unit itself. YET, on the 3rd Gen Prius there's a recall due to a bad accumulator tank from a supplier and we only replace the accumulator tank on those unless a certain code is set, then the entire unit has to be replaced... annoyingly hypocritical of Toyota and on par with their current trend of Warranty.
