chrisdowling84
Let me first start off by saying I did the VSC disable mod from this thread
http://www.toyota-4runner.org/4th-gen-t4rs/79426-disable-vsc-trac-abs-without-damaging-factory-wiring.html Over a year ago. So I install the Toytech Ultimate 3 inch lift. I did the same install on my 2011 limited with no issues. But as soon as I turned the 4Runner on the VSC off, VSC trac, and ABS light came on.
I also installed a set of toytech front extended brake lines, and bled them afterwards. I bled them the same way when I installed my Tundra brakes on the front. So Im really at a loss as to what it could be. I took special care not to extend the lower control arm to the point where it was stretch the ABS lines, and even unbolted the line holders from the hub all the way to the top of the upper control arm so as to give it maximum length with installing the front coils.
Is it possible that maybe I need to bleed the system more? Or that the runner just doesn't like the toytech lines? Its the only thing I cant think of. I even double checked all my wiring for the disable I did, and checked all the fuses... WTF!
