VSC = type of limited slip?
CPayne5 is correct. In a nutshell the ATRAC system relies on open differentials to simulate a limited slip differential using brake modulation. Keeping in mind that torque will travel the path of least resistance (to a wheel with the least amount of grip), the system applies the brake to the spinning wheel(s), effectively transferring the torque to the wheels with the grip. This torque may be transferred across axle, or even front to back via the center differential. Hope this helped.
2wd models will have ATRAC on the rear axle only.
For 3rd gen 4runners (1996-2002), ATRAC was present on 2001-2002 models.
"Automatic limited-slip" = new marketing slang for ATRAC used by Toyota and other manufacturers.
VSC = vehicle slip control; it prevents oversteer and understeer...basically, it keeps you on your intended path.
So then in fact my 2004 Sport V6 will have the ATRAC which is a limited slip?
4wd 4runners = ATRAC on all 4 wheels which is equivalent to having LSD (limited slip differential) on both front and rear axles. Your center differential is also LSD (Torsen LSD). So, basically, you have 3 "LSDs" on your 4wd 4runner.
2wd models = ATRAC only on the rear axle which is equivalent to having a LSD in the rear axle.
Although ATRAC and LSD are two different thing, they FUNCTION (in practical terms) similarly...aka, they help your 4runner move forward over poor traction surfaces. Therefore, auto manufacturers are using these terms interchangeably to confuse consumers into thinking that their car has some new advance technology, when this technology has been on cars since the late 90's in Land Rover Discovery and Mercedes ML.
Sorry, but this "ATRAC" thing is not even CLOSE to what a Limited-slip differential is like. Trust me, I've had lots of RWD vehicles both with and without.... this is nothing like a vehicle WITH a limited-slip diff.
Ricky
Ricky
I assume that you're talking about a CAR, instead of SUV. ATRAC is equivalent to LSD in off-roading or in snow. However, if you're talking about racetrack, then i agree with you.
Yeah, and since 99.9% of all 4Runners made never do any serious off-roading, there's no reason not to have it as an option you can add on to it.
With most GM trucks, you can add an LSD for only a couple hundred bucks... Not that I like GM in the slightest, but I don't see why Toyota couldn't do that.
Ricky
Ricky
The system in the 4th gen works as good or better then any limited slip/posi diff I have ever had, and I ordered it in every domestic vehicle I
Here's my thoughts,
I just picked up a 05 sport v6, traded in a bmw. Now I have been driving rwd cars in the snow for the past 15 years. I got my 4runner to the end of the drive this afternoon and I was stuck in 3" of snow. The driver side wheel had traction, the passenger side had none, almost as if on ice. In 2wd, i mashed the pedal and nothing, the computer was trying (I guess) to get me moving. After putting in reverse and getting out ot he rut, I was able to move forward and get unstuck.
If I had one of my previous cars w/ rwd and lsd, I would have had no issue.
I hate to be forced to use 4wd to move about when 2wd with a lsd would be sufficient.
I still miss my 93 BMW, last year before traction control and last w/ lsd. I used to joke that my right foot was my traction control. Still feel it does a better job than the computers that are in todays cars.
What kind of LSD did your previous cars have?? A Torsen LSD (found in previous IS300, Miata, etc.) would NOT be any better in your situation.
In offroading situations, ATRAC has the potential to be better than LSD.
Zero traction at one wheel * LSD does not equal traction at the other wheel. LSD needs some traction to work.
ATRAC does not care that you freewheel in the air...it will still have the ability to send traction to the other side.
When you say "nothing" do you mean no engine power? Sounds to me like maybe a VSC issue, not ATRAC.
You were stuck in 3" of snow ???? I'm sorry I find that a little hard to picture with a 4 runner or any type of truck for that matter.
I can vouch for him in this situation. When in 2wd with stock tires, the traction control is aweful. Basically, if neither tire has 'traction' it will cut engine power. You can have the pedal on the floor and it will just idle with no wheel spin. I hate it. I haven't encountered this problem since I got my new tires, though.
