Want to steal a part from a GX470!
revlis240
Will it work? If its do-able, i can use the embedded mic instead of my aftermarket mount (see pic) and have ambient lights. After having ambient lights in my bmws for so long, its a nice thing to get used to!
Attached is the 4runner overhead console.
And the Gx470 overhead.
I need to take a measure of both of them and see!
Abe
Or, just buy the overhead piece for a 2006-later 4Runner with bluetooth navigation. They have the same microphone setup.
This is correct. My 06 has the mic up there.
Hello. The Lexus GX470 overhead unit does in fact fit perfectly. I don't have the part number so sorry, can't help there. The connector is actually different too, so I used a little ingenuity to make it work. It's nice to have the lamps tied in to the door circuit now, along with the LEDs which are installed in it, lightly illuminating the center console.
Very worthwhile project! I'll see if I have any pictures of it out, and installed.
simple said:
Wait... why would you ever want to give up that stylish, and functional sunglasses holder?
Yes, that is something I discovered today. The GX470 piece does not fit normal sunglasses.
Yeah, personally I think the sunglass holder in either is pretty useless. Seems to fit the radio remote just fine though. Anyway, here's a pic of the overhead installed in my 4runner...
Is it possible to get more information on this? How difficult was it? What has to be done to the connector to make it work? How long did it take you? Any other pictures?. Thanks
Hey guys. I'll try to find some pictures of it apart (if I have any). Again, I don't have the part number, and I can't remember how much it was as I purchased several items when I bought it.
The connectors between the two models are completely different. The connector receptacle on our 4runners is part of the assembly so I used a Dremel w/ cutting wheel to seperate it, and then I basically just hacked off the connector from the GX470 one, then soldered the respective wires onto the 4runner removed piece.
Of course, since the GX470 part also has the ambient lights and the door switch input, there are a few wires left out. For this, I used a mini-molex connector that I already had to make another quick disconnect plug, and ran those wires for lamp power, ground, etc.
Obviously, you can do it any way you decide would be easiest for you. I chose to reuse the receptacle off of the 4runner assembly so I wouldn't have to replace that mating end. In hind-sight, it may have been easier to just replace that connector with a larger connector (with more circuits) so all the wires would fit in the one connector. I do a lot of projects so have several different mini-molex connectors, so that's what I used. I'm sure you could also use computer style connectors as well if that's what you have available.
Ok, I did find a picture of the overhead console wiring connector / removed part from the 4runner console with the GX470 console wires soldered to it. In this picture, I finished soldering the wires, but it isn't cleaned up, and I also put epoxy over the solder connections, and taped it up to insulate. But you'll get the idea.
I've also labeled the wires so you can see what each one is for.
Let me know if you have any other questions... I'll do my best to answer.
Jesse1
