Koz
mjuenem said:Actually the graph you pasted shows the opposite. The only true measurement of viscosity is the cSt listed above (called centistokes). A higher centistoke number is higher viscosity. You will notice that in each case where the temperature rose from 40C to 100C, the centistoke number went down. The viscosity did not rise.
Mark
Look at the last line for 10w-30, at 100 degrees it says mid 20 weight and at 212 degrees it says low 30 weight. Same thing for the 5w-30 and the 5w-20 shows low 20 weight @ 100 degrees and high 20 @ 212.
Koz
