Warn semi-hidden winch bumper & sway bar issue!?
Spanky4R
I had the warn semi-hidden winch bumper installed and the supports for it are extremely close to the sway bar. I can slide a business card in between them. I am wondering what the danger or possible issues with these being so close could be. Some have mentioned a sway bar relocation kit or grinding the support for more clearance. Please help!
A looks a little snug even maybe too close to the radiator support brackets...don't know if you have a lift. Might want to look at radiator support and skid plate drop spacers and sway bar relocation brackets...let others weigh in though
I guess it would be minimal? Less roll in turns...in reality, you could remove the sway bar but it would cause higher roll risk. It could be annoying hearing metal on metal clanking unless it hasn't been a factor to now...
That's all I got
Ok, but what is the danger of it or is there no danger
Since you had it installed they may have tried to fit it as close as possible to the body. If you have tools you might try loosening the mounting bolts and see if there is any wiggle room in the mounting holes to get you some more clearance.
Ok, I'll take a look. My main concern was it causing damage or failure overtime or when offroad. I may just be a little paranoid. Thanks guys.
