New bumper!!!!
Well look what arrived! Got some work to do now.
Packaging
Unwrapped. It's HUGE! I weight is here and the bumper alone was 140 pounds powder coated. Plus another 5 for the bolts and brackets. As you can see I did not get the swing arm.
And like so many others, damaged in shipment
The corners need some cardboard on them for added protection, or maybe even fully boxed. It's a shame to have such nice work marred during shipment.
I'm not sending I back though, I'll just grind down the powder coat and paint it...
One last shot of the back as it is now... There's no going back from here!
Lots of plastic to remove. Protect the bumper cover well! That paint can be scratched by even looking at it!
Tow hook, Styrofoam, bumper cover mount brackets all removed. Instructions said to cut off two other bumper cover mount brackets sticking down from fender but I just bent them up out of the way a little (Might not have even been necessary). JUST in case I DO want to "go back" way in the future.
Leave on the trailer lighting socket. I initially took it off too but there was no reason for that.
Also have the exhaust hanger unhooked which is necessary. Now there seems to be differing opinions on this but in my case, with a 2014, in the end it turns out that it is
necessary to cut off the end of the pipe about 2 inches in back (towards the back of the car) from the hanger. When I got done no amount of bending the hanger would get the exhaust far enough from the bumper to prevent banging.
I plan on re routing it out to the side, but I wish I had cut it off at this stage because now that the bumper is installed, cutting it at that point is going to be much harder. (I have another picture down below that shows the problem.
Next day, pulled out in driveway for better access. First test fit. I initially had a friend hold the right side up while I put the bolts in using the tires on the left for support.
Temp quickly rose to a sweltering 95 by 10 am and lasted till the job was done. Ghod forbid you left a tool in the sun!
At this point I mounted with a couple of bolts so I could measure the distance from top of bumper cover to the bumper. There were some numbers floating around but they are different for different years and so I decided to measure myself.
My final cut numbers were:
At 5 1/4 inches from the tip of the fender flare, 5 1/2 inches down.
At 16 inches from the tip of the fender flare, 5 3/4 inches down.
From bottom of corner of rear light closest to liftgate, 9 1/2 inches down.
Now I don't want to be responsible for any bad cuts, so if not sure, measure yourself. This was on a 2014 SR5, even the trail or Ltd may be different. Also, This gives my a 3/4 inch gap without the rubber trim, about 5/8 with. This may or may not be enough depending on how hard you wheel your rig!
More...
