Was messing with my settings for when the car lock/unlocks...
cbaty08
Member
.. and now* my remote FOB buttons don't seem to unlock the car(?).
I pulled the second key out (we never use it, it stays with the paperwork for the car..) and it did the same thing.
This is a 2021 Pro fwiw, and the key still unlocks/locks via touch and starts the car.. I just can't use the buttons on the FOBs.
I feel like there is a software bug here, as all I had disabled, and then re-enabled (in hopes of getting function back) was the sound level for when you press LOCK/UNLOCK on the FOB.
Hoping someone here has the answer and can save me the trip in.. thanks!
Look in your owners manual under "Customizable Features". That will show what you can configure on your car.
Does that show all customizations possible, including those you can only access with a OBD fob like Carista, or just the ones the average owner can do with the fob?
Generally the owners manual "Customizable Features" shows all possible settings (three columns for settings using the steering wheel switches, settings using the audio system, and settings that can only be done by the dealer (or Carista)). There are a few exceptions.
I haven't looked at the manual in a while, didn't realize it showed all those hidden customizations like increasing the volume of the turn signal clicks.
Dealership found the wireless remote setting was turned off (used tech stream), turned it back on and sent me on my way.
Will see if I can’t break it again!
charlesz
