Washer Fluid Level Indicator
Pennywise
I came across a couple threads (and in the manual) relating to the windshield washer level indicator on the dash. From what I understand, it is standard on Canadian vehicles, but not to be found on American 4Runners. My question would be whether or not it would be possible to add it?
I ask this, because after some research, I finally found out that the unused connector hanging behind the passenger headlight is the one used for the level sensor for the washer fluid. It is a 2 wire connector containing a purple w/ white and the white w/ black wires, which according to the schematic, are the wires for the level sensor.
I did a quick search on Partznet and they sell the sensor for about $40. Alhtough it looks like the wiring is there, a couple things still elude me. The biggest one is that I couldn't find the indicator in the dash cluster. I used a flashlight's reflection to try and find it, but with no luck.
The favor that I ask for those North of the border, is that could you tell me where this indicator is (a picture would be great). I figure that it probably illuminates during the start up sequence, and if it was present in my vehicle, it would never light up since I don't have the feature.
Yes, I know, the washer level indicator is nothing to go crazy over, but it is a relatively cheap, functional mod. It also gives you an excuse to work on your 4Runner. What more could you ask for?
BTW, I have an '04 SE.
Thanks,
Tom
I'd like to know this as well. Granted I check it regularly, especially in the winter time, but it would be kindof a nice feature to have..
I've seen the little blue indicator light up when my fluid was low but it doesn't light up as part of the start sequence. I will try to remember to take a pic the next time before refilling. I've only seen it once and my memory isn't good but I think it is located in the bottom of the left cluster.
Kmvreter,
Thanks, I would greatly appreciate it. I have looked and couldn't see to find it on my dash. Usually items like this are standard for all models, but I tend to recall that there is different gauge illumination with the Limited (red needles) compared to the orangish needles on the non-Limited. I wonder if the limited dash has it, but the SR5 or SE do not. Very Interesting.
Boston_Runner, Good find. This may be related to the cluster as mentioned above. Any 4th gen Limited owners want to speak up?
Thanks,
Tom
My owners manual reads like a universal manual that says this is a Canadian only option, regardless of model.
The warning light is there on the 05 SE, mine came on recently. It is located on the right side of the left cluster, and is hard to see without bending over to the left a bit.
I will try to take a pic of it and post it, don't really recall if it comes on during the start sequence or not.
mine is on right now i will try to get a shot too u asap....my dig camera and computer are in a fight right now..
but the spot described is right
schwalmy
Though this is not the electronic solution you're looking for, I discovered this past week that the washer fluid reservoir has a dipstick for checking the fluid level.
Ambrose67
