Water leaking in on passenger's side
Can't quite figure out where it is coming from. Have a '04 V6 4WD and when it rains water trickles inside my T4R underneath the glove compartment right in front of the passenger side door. Not AC related and even happens when the truck is just parked. Has this happened to anyone else ?
I would look at the drain tube for the Sunroof that exits along the passenger A-pillar if you have a sunroof as your first culprit. I would also then look at the windshield cowling and remove any debris that may be there. If you can, try and get under the dash and see where the water is coming from, is it leaking out of the HVAC system (possibly indicating a leak through the HAVC air intake) or is it from the body of the vehicle (inciating drainage issues.) Good luck!
Yeah, my sunroof drain holes get clogged up a couple of times a year. Cut off a 4-5 foot piece of weedeater line and run it through...that should clear it out. I usually pour a little bit of water in afterwards to double check it. Works every time, so far.
lindwlson982
