weeeee's build thread
How the heck are you running those 305's?
I have the same lift, spacers, bmc, and I'm running 255s. I can't see 305's not rubbing on my rig.
Looks awesome btw
It fits! :boink:
I'm running similar stuff, and my 305s fit with plenty of clearance when I removed my wheel spacers (1.25" Spidertrax). No rub.
I have since put on 1" BORA spacers and had to trim a little more of the fender liner in the back of the front wheel wells. Stuffs nicely on the trails.
Yup, just need a really aggressive BMC depending on your wheel offset, and a lot of massaging on that mount near the back of the fender. Articulates just fine on mine, although I did lose the plastic fender cap and the back of the fender. New glass this month should fix it.
You tak really good pics man, what are you using to take them?
Thanks! Most of the pics are from either me or my buddies on our trips.
I'm shooting with a Sony A7II, [MENTION=56922]NoOneBetter[/MENTION] shoots Nikon, and my other friend shoots Sony A7RII.
glass fenders...:hippie::clap2:
Curious after the king install and roof top tent install how high was your vehicle sitting. Just trying to get an idea before I go the similar route (parking garages, daily driving, etc)
With a full load of gear and with 700# King springs up front, Icon Overland springs in the rear. Front is sitting around 2.75" of lift, 2" in the rear.
I'm in the market for a RTT and was wondering if you could answer a couple questions about your Airlander.
-How's the wind noise and gas mileage affected by your RTT?
-Is there room to store anything else in the hardshell besides the ladder?
-How does the tent hold up to strong wind gusts?
-How's the comfort inside?
Thanks!
Thanks!
Also, how'd you mount your RTT to your K9 rack? Did you make your own brackets?
Wind and gas mileage weren't bad. I'd say the biggest hit to my MPG was tires and lift. I'd probably estimate about 1.5MPG loss freeway. Right now I get about 13MPG combined on a good tank, so I haven't been too concerned.
I store my bedding, clothes, ladder, pillows all inside so I can literally roll up to camp, crank it open and get to bed. Since the RTT can accommodate full bedding, I've seen people use their comforters inside also. It might be a little hard to close depending on how thick your bedding is though.
So far I've run this through quite a few really gusty nights, including a pretty bad storm while camped on the edge of the Grand Canyon where it hit over 50mph. I'd say it holds up very well. While the tent construction is pretty sturdy, the zippers, flaps, and buckles will make quite a ruckus in really high winds.
As far as comfort, it's pretty nice inside. Longest I've been inside has been 8 nights, and I can't really complain. Since its a little smaller than standard tents, it does warm up rather quickly (which is a good or bad thing depending on your climate). On really cold nights I'll use an RV mattress heater pretty sparingly just to get the mattress up to temp. You can also buy thicker mattress material (or get a mattress topper) if you desired.
I'm running the Front Runner Maggiolina brackets for the K9 rack. DO NOT use the K9 brackets unless you want your tent to fall off, as it is not very heavy duty and can slip out.
This happened over some whoops on the Mojave Road:
Three of the 4 brackets failed at about 40MPH over the dunes, and my tent was literally hanging on by a single bolt.
Hope that helps!
Hope that helps!
Thanks for the reply weeeee! I decided I'm definitely going with an Autohome RTT, but I'm still deciding between the Columbus and the Airlander. Both look like good options to me. I am a little worried that the mattresses are so thin, but at least there's room for extra bedding in there.
I see that you had the Baja flat rack before the K9. Which one had the shortest clearance? I know you have to remove the sharkfin with 40mm legs on the K9, but considering I'll be getting close to my garage door's limit, I'm ok with that.
Are you happier with the K9? I'm a little torn on which one to choose.
Yeah, with the mattress you can add some memory foam or a foam or down topper on top if you wanted, or custom order a foam mattress to your desired thickness. Memory foam is a little more comfy but traps heat and condensation. Also if you make the entire mattress out of memory foam it'll feel like you're sleeping on a brick on really cold nights. I ended up ordering a slightly thicker and denser mattress for my RTT since I needed to replace mine after the old one eventually flattened out lol. Was about $100.
The Baja was cheaper, but the K9 is better built in my opinion. The welds are top notch. The Baja will eventually rust, but the K9 (being aluminum) will last a lot longer. I think the clearance is about the same for both since the Baja has the cutout for the shark fin.
Great, I appreciate all the info! About to pull the trigger on a couple big purchases thanks to you, haha :thumb3:
Hey man,
Coming from a former photographer, your photos are amazing. Any way you can link me a desktop quality version of this image?
Seriously great job.
Whoops, totally missed this! I can't take all the credit, I have some very talented friends that often come along on trips too ( [MENTION=56922]NoOneBetter[/MENTION] for instance).
Sent you a link to that image via PM.
Great looking rig WEEE.
Did you notice any drop in MPG when you added your steel bumper?
A tad bit, lost the most with a lift and tires. I don't really pay attention to MPG's anymore. [MENTION=56922]NoOneBetter[/MENTION] just installed a SW bumper, he might be able to share some exact MPG loss #'s. It's been a while for me.
Looks amazing!
Thanks!
How does one get in on one of these trips?
To be honest, most of the time it's just me and a group of friends. I've been thinking about doing a Norcal T4R run for some time now. I'll post something up in the regional forum once I have some free time.
tssawlson538
