weeeee's build thread
Thanks [MENTION=56922]NoOneBetter[/MENTION] for some of the photos, wouldn't be able to tell the complete story without your pics. And [MENTION=129593]MTN4RNR[/MENTION], hope you can hit this one next time, sorry you had to sit it out.
With my current build, it would have been more recovering for the group and with no guarantees on trail conditions, I made the right call. Bummed to sit it out, but all the more motivation to lift sooner (still looking for that $ tree). Thanks for sharing your awesome adventure that had a little bit of everything! Next time I will ride with someone and photograph/spot/be a winch b!*#h all weekend.
Joined a few friends including [MENTION=56922]NoOneBetter[/MENTION] for a short weekend trip to Black Rock Desert in East
Nevada
Nice Pics and I'm sure a learning experience too. with the tires......and there is no incorrect way to transverse the ladder ..when you are in "shape" ..pc goes out the window
Yeah, you definitely made the right call. Was challenging for some of the up-armored rigs with or without lifts, probably would've been bad going through the water section too.
Thanks! Yeah at least I didn't go headfirst down the ladder. Although I'm surprised I haven't...have had my fair share of nights I don't know how I climbed up after some drinks..
That's an easy one...OP has the ball though
Details on the propane tank holder?
A little more complicated. Will require some re-configuring of the swingarm. Single swings won't have an issue, dual and your propane tank will be in the way of the hatch opening unless the swingarm is fully extended past the detent.
You have past your multi-quote exam...drink on and weeee down that ladder however which way choose
Propane Mount
LUCKY for me I have the Single Swing Out......:whoo:
Lift would have helped, biggest issue with this trip was a lack of winch and recovery points. I could have been drug out of a few of those obstacles if I had solid, accessible winch points. But I would have just pissed off Andy and the others if I kept getting stuck with no self recovery :thumb3:
#pickyourbattles
Powertank 5-gal propane holder, custom weld job to the CBI dual jerry holder. I could've easily drilled holes into the jerry can holder and put bolts through, but since the jerrys have a tendency to expand under pressure I opted to weld another plate to have the bolts run through instead.
Clearance from back glass. Have run multiple high speed runs and wheeling runs, have not had issues with clearance.
If you run the CBI with dual swingouts, you'll probably run into a problem with the propane tank being in the way of the hatch opening. There's not really a good way for the tank to be positioned without it being in the way.
You'll need to remember to go past the detent which will clear the swingarm from the hatch. I'll probably re-weld this piece to get it to open further.
Something seems off about the hitch mounted spare. Is it flat? Am I just seeing things?
Sent from my XT1585 using Tapatalk
Yeah, probably just the angle on the lens making it look funny. Here's a different angle/different camera, same hill courtesy of [MENTION=56922]NoOneBetter[/MENTION].
That makes sense. And now that I see it on my computer instead of my phone, it looks normal. Not sure why it looked so odd on my phone.
What made you switch from the DO front bumper to Shrockworks? I've been considering the DO since I can pick it up to avoid freight shipping.
Sorry for missing your PMs! I actually switched because of an accident. While the Demello held up well with no damage, insurance made me switch because it was missing powdercoat and I needed to repair it before they authorized the remaining repairs. The wait time on a new Demello was a bit more than the SW and I also didn't mind the change.
That being said I do have some feedback.
-The Demello is built very nicely with weight savings in mind. The internal structure/skeleton is framed and saves weight wherever possible. Whereas the Shrockworks is very stout and heavy. Depending on what type of wheeling or off-roading you do this may be an important consideration.
- The SW bumper hoops hug the body a little bit better than the Demello and they are closer to the body. I do have issues with the very top of my headlight cutoff hitting the beam of the bumper so I don't get as crisp of a cutoff. Minor annoyance that I can live with.
- Demello no longer sells their headlight filler pieces and recommend that you fab your own. The Shrockworks filler pieces aren't exactly a great fit either. If going SW bumper you cannot use anything besides the SW filler pieces. With the Demello bumper you can use a cut stock bumper which fits a bit better. You can also cut a stock Limited bumper without the gills and it looks very clean.
Hope that helps!
Just went back and read through your trip report. Looks like a fun (and crazy) time. It's truly making my itch to get out west much stronger.
Thank you sir! :hatsoff:
Eventually I will get bored of all the western trails and try to make my way over there as well.
erinobr2000
