Well, I am little stressed to say the least.
2002, 193k miles, original motor and transmission. Trans filter replaced @ 163k by PO, I had timing belt/water pump/tensioners/cam seals replaced @ 186k, also brought it over to Toyota to have the transmission flushed at the same time.
On my way home from work today, My transmission started acting odd. When I let off the throttle it would almost feel like it was down shifting and slowing me down. It would accelerate fine, then I let off the throttle and it slows down. For kicks and giggles I kicked out overdrive, and it no longer did it. Same thing being in 2. Also for kicks and giggles I turned my Torque Pro App, and realized my transmission was running way hotter than normal, especially since it's only 22F here. It was running about 180-190F @ about 35mph. I pulled over to check to make sure I wasn't leaking any ATF, and saw no leaks. Then I checked my fluid and it seemed quite a bit darker than when I checked it the other day in the shop, but completely different lighting. When I wiped it on my finger it was still pink, but in comparison to 2 days ago I think it's darker. Also attached is a picture of the fluid color. Not the pink I'd like, but I've seen a lot worse.
My coolant Reservoir is full and doesn't look contaminated, also my radiator itself is full and doesn't look contaminated.
Was hoping maybe someone had some insight?
P.S. I have searched on the forum, and can't find anything that describes my problem.
Transmission Fluid Color
