how do i post something?
I think you just did... :hatsoff:
Hi,
It´s my first post, I´m from Brazil and I´ve a 4runner 98 3.0 TD, I bought it six months ago.
I´m reading and learning a lot here... thank´s
Bem vindo ao nosso site! O 4Runner e um ótimo carro para emfrentar as estradas do Brasil.
Gang, I have a 2000 T4R and have the same problem. Have any of you solved this condition.Hello to all. I have a 2001 4R, 92K, love it. About a week ago I started hearing a noise/vibration when I reached 70mph. I was on my way to New Orleans (about 500 miles). At that time I could push it on up to 76mph and the sound quit. By the time I got back home the sound had changed so that it starts at 63mph and doesn't stop all the way up to 80. I've put new tires on it (it was ready for new ones anyway), checked drive shaft and u-joints, pulled on the tires top and bottom with the wheels off ground and there is no slack as in worn wheel bearings, I checked fluid in differential and transmission and levels are good and color is good. When I put the trans in neutral at high speed, the sound is unchanged as in no association with engine rpms. Finally took it to a friendly mechanic who put it up on the rack and 2 mechs spent 15 minutes checking everything they could think of, finding nothing that seemed out of the ordinary. He suggested that I might try new shocks or go ahead and replace the drum bearings, more from a lack of ideas of what else to try than seeing any issues with them. The noise is not loud, must have windows up and radio off to hear it, but seems to be getting worse as in the wider range of speeds at which it can be heard. I hate to spend time and money on these things just as a shot in the dark. Has anyone out there had a similar experience, or have any ideas as to what might cause this? I'd appreciate any thoughts on the matter. K
Hola a todos como estan ya escribi en otro post tengo una TOYOTA SW4 3,0 TD 1997 espero no les moleste porque escribo castellano pero no se nada de ingles leo algo pero de escribir nada , uso el traductor de google para entender los post .PERO como megustan las RUNNER trato de entender
MUY BUENO EL FORO LOS FELICITO , y si hago algo mal espero me perdonen hasta que me acostumbre
SALUDOS ALEJANDRO
Hello everyone how are you already wrote in another post I have a 3.0 TD 1997 TOYOTA SW4 hope do not mind because I write Castilian but not read something no English but to write anything, I use google translator to understand the post. BUT as I like trying to understand RUNNER
GREAT FORUM congratulate you, and if I do something wrong I hope they forgive me until I get used
ALEJANDRO GREETINGS
A fenrisx muchas gracias
Una pregunta de que medida son los suplementos que ponen para levantar los amortiguadores y dar mas altura a las camionetas (4runer ) segun dicen de una pulgada para adelante y casi dos pulgadas para atras
es asi .
Algunas empresas hacen muelles de recambio, que se levante la 4Runner 1 a 3 pulgadas. También puede comprar un espaciador para poner en la parte superior de sus resortes para dar un ascensor. También hacen lifting corporal que levantar el cuerpo, pero dejan la suspensión de la misma altura.
Perdón por la mala traducción.
dfgdhggjjkkl
fdgghhjkkl;'5r
dsafsadgfhjhjkjl
