We're to buy stronger torsion bars and lift
Are you allergic to Google, is that what this is all about?
You're likely to get more helpful responses from people if you stop treating us like a vending machine and start putting a little effort into finding the information you want. You can start by going to Google and typing "1994 upgrade torsion bar". Come back when you have some real questions.
Actually I have done that and everyone has been real helpful besides you being a smartass! I have researched and was trying to get opinions where to buy and like if site sponsors had them.
...I have researched and was trying to get opinions where to buy and like if site sponsors had them.
OK, we would need to know what brand of t-bars you've chosen before we could tell you where would be the best place to get them. Different places have better prices on one brand than others a lot of times.
Are there any factory swaps for the 4Runner as far as torsion bars or torsion keys? Such as with GM half tons Dodge bars can be fitted as well as GK and GY torsion bars from 3/4 ton and 1 ton trucks to achieve lift. Same with using Ford torsion keys to re index the spring rate and achieve lift.
I know theres some axle swaps guys have done, not sure about suspension components.
Ok, I'll give in and throw you a bone since you came back. Follow the link below. Go to the bottom of the page where it says "Sponsors". You find the companies that sell everything you are looking for. Most of them specialize in Toyota.
http://www.toyota-4runner.org/
I went with Sway-A-Way 25mm bars for our 1990 4wd, but did not lift it beyond factory spec. I believe they make a 26mm race version, but the 25mm are pretty stiff to begin with(big difference over the factory bars). Doubt most would want more then the 25mm's.
If your doing an R&R of the torsion bars, you might consider replacing the front control arm bushings(upper and lower). I went with urethane.
regards
