Wetsanding/Colorsanding
kylebacc
Banned
Anyone have any input as to weather they think this is a good idea? Anyone done it/had it done?
Goods?
Bads?
Thanks,
Kyle
Goods?
Bads?
Thanks,
Kyle
Goods: you can remove minor surface imperfections with super fine grit sandpaper. 1500 or higher.
Bads: Sand too much or burn thru with the buffer and you just blew $500 to get the panel painted.
Verdict: Don't do it unless you are a professional. Why would you want to remove a layer of clearcoat?
It's really easy to do BUT really easy to f*ck up. Just use the finest grit possible and continually wet the surface. Also, don't use a circular motion- move back-and-forth. If it is done right you will be left with a smooth, true show car shine. No polish or compound can compare to a sanded finish.
MaximussK
