What are people doing to cover the rear mud flap hole
I know this is kind of an old thread, but figured i'd update for anyone else looking for a mudflap delete option.
Found these from Revtek for 39.95 and just installed them on my 2020 TRD Pro.
had no idea these existed. purchased - thanks
Just a heads up, for some reason it only comes with 2 pre-drilled holes for an actual bolt, and then 3 pre-drilled places for push tabs.
I'm not sure why they didn't pre-drill the center bolt hole, so i lined it up with my factory flaps and drilled it myself. Now I have 3 secure bolt points and 3 push tabs securing them.
The only downfall I see is that on the passenger side, its not flush against the wheel well, so technically this could be seen as a "catch all" The factory flap has an offset piece to sit it flush against the wheel well.
On the driver side, it has a plastic liner for what I assume is to protect the filler tube for the gas tank. So on the driver side, the delete plate fits pretty tight up against the liner, so not mush debris can get in there.
Here is a pic of the factory flap with the offset and a picture of the Revtek mounted. You can see there may be an area to catch debris. Not a deal breaker for me though.
Like the RevTech, They look very nice. Here are pics of my Limited splash guards, never had mud flaps.
About time someone offered something like this. I trimmed my stock flaps and they fit ok for me but these are a great option. Thanks.
Found them at Rogue Offroad. They are $39.95 and $34.50 shipping. Nope. I will be cutting mine instead. I've already removed the mud flaps. Looks so much better without them.
I just cut mine and they look less than good, but they are good enough and nobody would know unless I pointed them out. More importantly they keep the crap out of them rear bumper.
I also used the Revtek mudflap delete kit. Got mine from Amazon as well. Great fit, very clean...
