What are your HIGHWAY mpg's?
Year: 1997
Tire Size: 265/70/16 (currently)
Gear Ratio if you know it: 410
2WD or 4WD: 4WD
Modifications that affect MPG: Mild lift, Trutrac LSD (?), Airaid (?)
Automatic or manual transmission: Auto
4 cyl or 6 cyl: 3.4 V6
Current highway fuel economy: 20 average
Riceye I am looking forward to your response! Have a safe trip.
I swapped out my set of BFG 265/75's in an E for a set of Duratracs in the same size but a C load. Immediately noticed a difference not only in mpg's, but in general power while driving. May be a little moot now being supercharged.
Year: 1996
Tire Size: 265/75/16
Gear Ratio if you know it: Whatever stock is
2WD or 4WD: 4wd
Modifications that affect MPG: NO modifications.
Current highway fuel economy: I see 17mpg driving 50-70mph on my daily commute.
interesting because I feel like this is really low fuel economy, but my truck is totally stock.
Pre 4WD swap:
Year: 99
Tire Size: 225/75-15
Gear Ratio if you know it: 3.73
2WD or 4WD: V6 2WD
Modifications that affect MPG: stock
Current highway fuel economy: 24mpg at constant 67mph (was as high as 26 when new)
4WD swapped
Year: 99
Tire Size: 265/70-17 BFG AT load range C
Gear Ratio if you know it: 4.10
2WD or 4WD: 4WD
Modifications that affect MPG: tires, air raid intake (?), full skids (?)
Current highway fuel economy: 22mpg at a constant 67mph
-Charlie
Year: 1998
2WD or 4WD: 4WD
Modifications that affect MPG: Balding tires
Current highway fuel economy: 24 on my last trip with this setup. It went down when I put the roof rack on and went to 4.3.
V6 4.3 liter
Manual or Automatic transmission: Manual
Eidt: I checked this against the 5 mile markers on I5 and it was EXACT.
Thank you for the important list of factors update. I have added to to my original post. Anybody that has already posted, if you don't mind editing your posts to reflect transmission type and engine size that would be very helpful. Sorry in advanced!
This is very interesting. There are threads that have spoken about going from stock 265/70R16s to 265/75R16 (32s) that their gas mileage plummeted. Considering that some of you with the 32s are getting nearly 20 mpg highway still is interesting. Maybe it is just in the city that 32s kill fuel economy?
Year: 2000 SR5 Auto Trans
Tire Size: 275/75R16
Gear Ratio if you know it: Stock
Modifications that affect MPG: Recently cleaned MAF and Throttle Body Intake
Current highway fuel economy: pre-cleaning: 16-18 Highway; post-cleaning
- recently got over 26 on trip to Oregon Coast (hilly, secondary roads, all pavement)
Cleaning the MAF sensor and the Throttle Body made a huge difference
in MPG (Scanguage readings). In town MPG is 5 mpg higher too. Kind of surprising - I've owned the truck for a year, had 1 owner and 136k miles on it when I got it- really thought I just had to live with the crappy mileage due to the bigger tires, but no - actually cleaning things made a big difference.
Year: 2001
Tire Size: 315/70R17 KO2(34" actual height)
Gear Ratio if you know it: 4.10:1
2WD or 4WD: 4WD
Modifications that affect MPG: 5 speed swap, manual hub conversion, 2.5" lift, 9" wide wheels.
Current highway fuel economy: Got 19.8mpg on my last road trip. Avg speed of 70mph. Lots of hills and 4k RPM grade climbs.
WOW that is crazy. I've never heard of that much of a difference from cleaning MAF and throttle body. Also never seen for that mpg from that tire size. Besides your trip, what are you getting on normal highway trips?
One has to specify is it's V6 or L4.
My V6 4runner 4x4 rear 4:10 ratio is doing 17 highway at 65 cruise and 11ish city (my V8 2000 AWD 6900 lb LandCruiser is doing 16.6 highway at 70 and 11 in the city).
Fun Thread.
Year:1996
ENGINE:3RZ 2.7L
Tire Size:235/75r15 Load Range C A/T tire
Gear Ratio if you know it:4:10??
2WD or 4WD:4WD
Modifications that affect MPG: 1.5 - 2'' lift
Current highway fuel economy:24.7 mpg or 9.5 L/100km
Automatic or manual transmission:5spd
With 2 people and approx 300lbs load. Repeatable over several years.
Assuming you're talking to me-
I average around 16 mpg from normal driving.
Unless I'm off road, 15 is as low as I ever see, and I don't see over 17 too often.
My commute is 21.2 miles each way. In the morning, it's a free-sailing 40-70 mph drive. In the evening, it's 5-70 mph.
I calculate my mileage every tank, and have found it does me no good at all to "be easy on the throttle". Just drive it, and don't be scared to rev it out, cause it ain't hurting your mileage! Of course, I can only speak for myself- and a buddy who has experienced the same results.
Year: 1996
Tire Size: 235/75/R15
Gear Ratio if you know it: not sure
2WD or 4WD: 4WD
Modifications that affect MPG: OEM mini header, removed running boards, 1"lift
Current highway fuel economy: 23mpg at 70mph
Automatic or manual transmission: Automatic
4 cyl or 6 cyl: 4 cyl, 2.7 3RZ
When I posted my results I should mention where I live in Pennsylvania I'm either going up a hill or down one. The grades are hardly flat. Anyone that drives 81 north of Harrisburg or 78 between the 81-78 split and the New Jersey border know what i'm talking about.
Yes I was talking to you. My bad for not using the quote function. Really I don't feel that is terrible fuel economy considering how big and heavy 34s is.
1997
285/55/16
Gear Ratio if you know it: N/A
4WD
3" Lift, 1" Body Lift, Heavy Tires, 400-500 LBS Bumpers, Sliders and skid-plates.
16MPG
Automatic
3.4L V6
Year: 1997
Tire Size: 285/75/16
Gear Ratio if you know it: unsure with an E-locker
2WD or 4WD: 4WD
Modifications that affect MPG: 2-3" Lift, roof rack, bumper, full skids
Current highway fuel economy: 14 mpg average :/
4 cyl or 6 cyl: V6
<img src="https://farm5.staticflickr.com/4597/25300879628_991f65fa59_c.jpg" width="800" height="450" alt="20171210_082051"></a>
2001ATL
