What are your HIGHWAY mpg's?
I'll play too:
1998 sr5 3.4 SC'd 2.0 pulley, 7th injector 40k on motor. must run premium!
5-speed
Dual Transfercases
4.88:1
35x12.5R17 Goodyear MTR's
4inch lift
Rear Disk Brake conversion
Rear Full Float
no front or rear bumpers
Average milage 12mpg town or freeway.
I have a lot of extra drag with all the mods.
2000 3.4
5-speed
Bone stock
Fresh tuneup (plugs and wires) 1 month ago
265x70R16 c loads
255K
When I first got it and got it up and running I was getting consistently getting 14mpg around town. Not had it on a road trip yet.
Last week I seafoamed the upper intake and ran a can through the crank case for a tank and a can in the gas tank. Then new oil change.
Since then I have had 2 tanks of gas go through it have got 17mpg around town. I suspect that freeway I will be in the 20 mpg range, and I get to run low grade gas.
Year: 1996
Tire Size: 285/75R16
Gear Ratio if you know it: 4.30
2WD or 4WD: 4WD
Modifications that affect MPG: mud terrain tires, 3" lift
Automatic or manual transmission: Auto
4 cyl or 6 cyl: 3.4 V6
Current highway fuel economy: ~17
This is considering the road is pretty flat and there's not a lot of wind and when going about 70MPH. If I go 50MPH for a while, I can get up to 23MPG! I've noticed my rig prefers that speed for fuel economy as it's right around when the torque converter will lock up and the RPM is at it's sweet spot.
1998 3.4L Auto
Getting 18.8 on the road right now from Monterrey, MX to Waco, TX then to Austin (~700 miles). Fully loaded with a 20 cubic foot Sears cargo box/brick on the roof. Keeping it at the speed limit (75) or a bit above with the flow of traffic. I use cruise control a lot. New Michelin Defender LT/X 265/75/16 and 4:10's. Very little altitude change.
1998 3.4L Auto
How well does the truck cruise at 75 with that set up?
My info with some statistics from my phone app thingy that I started using toward the beginning of the year...I think.
Year:*1997 LTD
Milage: 430k+
Tire Size: 265/75/16
Gear Ratio: 4.30
2WD or 4WD: 4X4
Modifications that affect MPG: None
Current highway fuel economy: 21
4 cyl or 6 cyl: 6
Year: 1997 Limited
Tire Size: 265/75R16 Load Range E, Mud-Terrain Tires
Gear Ratio if you know it: 4:30
2WD or 4WD: 4WD Push Button with RR Diff Lock
Modifications that affect MPG: 3" Lift
Current highway fuel economy: Approx. 15 MPG
Automatic or manual transmission: Automatic
4 cyl or 6 cyl: 5VZ-FE (V6)
Vehicle is in need of a major tune-up (Fuel Filter, Plugs, Wires, (maybe even coils), 2x O2 Sensors (non-cali)). And also needs new U-Joints.
Year:*1997 LTD
Milage: 430k+
Gear Ratio: 4.30
2WD or 4WD: 4X4
4 cyl or 6 cyl: 6
Nice. What phone app is that?
for me a lot depends on time of year. Summer with 265/75/16 KO'2s highlander springs, few other minor mods, I can expect 20mpg
and of course if I'm playing in the back roads, less
winter, I think they put more ethanol in the fuel up here where our day temps are rarely above 36. studded 265/75/16 tires, more 4wd use and more locker use
16-18 maybe have not seen it go under 14 and that was last winter when I was constantly in 4wd and 105 inches of snow on the ground.
2000 v-6 auto, borla muffler, spectra intake. Plugs and wires have about 30k on them, running all synthetics
Year: 2002
Tire Size: 285/70R17 BFG K02
Gear Ratio if you know it: 4.88
2WD or 4WD: 4wd
Modifications that affect MPG: 2UZ :biggrin2:, Mild lift
Current highway fuel economy: 18.2
4 cyl or 6 cyl: 2UZ 4.7L V8 :)
I just bombed down 101, currently sleeping in a rest stop somewhere north of San Luis obispo. With my scan gauge, going dead flat at 55-60 mph I think I'm averaging about 25. Overall for the whole trip it's about 22-23 over about 2000 km but that included some really rough windy roads in the lost coast s of eureka. 3.4 v6, manual transmission, no lift, Michelin ltx's balding, 265/70 r16, custom roof rack with wind faring and bike on the roof ( laying flat). I don't know why my mileage is so high but it's true. I've verified the odometer with the 5 mile highway calibration marks. It was 2 mpg higher on a previous trip without the roof rack.
BEFORE people start yelling at me for "not researching" hear me out. I have actually read 20+ threads that have anything to do with gas mileage and what I have found is that most of them are giving mixed city and highway MPG's. We all know that pure city driving is going to give dismal fuel economy even for bone stock 3rd gen. So what I want to start a thread for HIGHWAY only fuel economy.
Please list your answer in this format:
Year:
Tire Size:
2WD or 4WD:
4 cyl or 6 cyl:
:cheers:
2001
285/75R16E
4:10
4wd
3" lift
17.3mpg
Auto
3.4L
After a 1400 mile trip from Ohio to Colorado (first long trip with the 1999) this is what I'm seeing. I averaged about 74 MPH or so. A little faster than I usually drive but I was anxious to get to the mountains!
Year: 1999
Tire Size: 265/70R16
Gear Ratio if you know it: 4:10
2WD or 4WD: 4wd
Current highway fuel economy: 18.3
Automatic or manual transmission: Manual
4 cyl or 6 cyl: 6 cyl
A couple things to note about driving in the winter:
Most people blame lower MPGs during the winter on the winter fuel blends, but there is another factor that plays in much more: air density. Winter fuel blends have been shown to yield about 2% less energy whereas an air column at 20 degrees Fahrenheit is about 10% more dense than an air column at 70 degrees Fahrenheit. That means the vehicle is working quite a bit more to maintain a given speed in order to overcome the denser air during the winter.
So, if I've seen a 10-12% reduction in fuel mileage due to the combination of winter blend and denser air, my equivalent summer average would be a little over 20 MPGs, all other things constant. I still need to do a tune up so hopefully that goes up a bit more.
Great for being 20 years old. No problem maintaining speed but you can tell a lack of power going through hill country in Texas, which really isn't a good test for altitude change. Overall very happy with the setup.
Wahoo 75 posts! Thank you to everybody! Hopefully this thread will help some future people. Anybody else who wants to contribute is welcome!
Year: 2001
Gear Ratio if you know it: stock
2WD or 4WD: 4WD (but used 2WD on road trips)
Modifications that affect MPG: stock except removal of the "spoiler"? over the 3rd brake light
Current highway fuel economy: 20.2-20.6 @ 65, 19.1 @ 75 (several road trips)
4 cyl or 6 cyl: 6
32 PSI, fresh 80w-90 in differential
Have NOT cleaned the MAF in forever.
I hear that helps. Will clean mine and report back after next road trip.
Year: 98
Tire Size: 245/75/16
2WD or 4WD: 4WD
Modifications that affect MPG: none
Current highway fuel economy: 19.8
Automatic or manual transmission: manual
4 cyl or 6 cyl: 6
all stock. I live in the foothills of the Front Range in CO, and most of my highway driving is on i-70 with non stop steep grades to get to skiing, with occasional trips into Denver and the stop and go traffic that goes with that. i've put about 5 tanks in so far. mpg calculated by trip meter divided by gallons in since last fill up. been consistently right around 19.8. I've been doing a lot of 4wd snow driving on this tank, curious to see how that affects it.
1998 T4R
Tires: 265/75/R16 Mastercraft
Gear Ratio: 4.10
Engine: 3.4 L 5ZVE
Trans: 5 Speed
3 Inch Toytec Lift, Rola Rack on Top, Rhino Bar on Front
Miles on Vehicle: 227K
Highway Mileage: '@ 70 MPH---about 21 MPG---average over last 900+ Mile Trip down to Colorado
'@ 80 MPH---about 19 MPG--average over last 900+ Mile Trip from Colorado back home
Garo
AlaskaRuss
