What are your HIGHWAY mpg's?
Year: 98
Tire Size: 315/75/16
Gear Ratio if you know it: stock 4.10
2WD or 4WD: 4WD
Modifications that affect MPG: 35's, armored to the T
Current highway fuel economy: 16mpg highway, 15mpg mixed (after 12% correction for tire diameter)
Automatic or manual transmission: manual
4 cyl or 6 cyl: 6
IMG_7559 by Brandon Faliszewski, on Flickr
DIESEL fuel economy.
Year: 2000
Engine:Diesel I4 1KZ-T
Transmission: Manual R150F
Transfer: 4WD/Multi-mode VF3AM
Gear Ratio: 3.91 RR Locked(from Tacoma)
Tire Size: 225/75/R15
Average highway fuel consumption on warm days (above 60degrees)/70MPH: 28 MPG
Generally no load.
Depending on diesel quality in the region (Balkans) the MPG can be as low as 23 or as high as 33.
Lowest I had was around 20(often), Highest 35 (rarely).
I don't get average mileage when i drive it on motor oil, around 23
In winter MPG is usually lower by a 3/5 miles.
Year: 2000
Generally no load.
You're cheating.
I finally got the new 32s on! Great MPG!
Year: 1997
Tire Size: Trail finder all terrain passenger rated 265/75/16
Gear Ratio if you know it: 4. 10
2WD or 4WD: 4wd
Modifications that affect MPG: lift and 32s
Current highway fuel economy: 24
Automatic or manual transmission: auto
4 cyl or 6 cyl: 6 cylinder
Sent from my A0001 using Tapatalk
You're cheating.
Haha Hey now
The price of the cheaper diesel here is $5.18 a gallon as of 25/01/2018. And the 4Runner has 18 gallon tank! That's 90 bucks to fill it up here.
While in Kentucky it's like $2.20 which is like 40 bucks! I think you are better off still!
Haha Hey now
Oh I figured, I just think a diesel 3rd gen is pretty cool. :cheers:
What's also cool is the latest Hilux Surf 3rd Gens (2001-2002) engine - 1KD-FTV - it has 180hp and 310lbft of torque.
It has a turbo, an intercooler, and is as economical as my 1KZ-T. Mine only has 125hp and 210lbft.
I just took my 2001 SR5 on a 6 hour trip up north last in November, running about 65mph(mostly cruise control) and about half the trip was flat highway, the other half being in some elevation and more winding roads. Temperature was between 15-30 degrees on this trip and My 4runner got 19.5 mpg..which I was pleasantly surprised with.
Year: 2001
Tire size: 265/75/16
4wd
Modifications that affect MPG: K&N air filter, some extra weight
Current Highway fuel economy: 19 MPG
6 cyl
24 mpg
Have you seen any other replies in the 24+ range?
I didn't think this was possible, until I pulled it off during a road trip last week. I want to do some research and get some facts before I post the details -- maybe this weekend.
97 5 speed
4.30
285/75/16
Fully armored
Storage box
Roof rack
Just drove 70 mph. Scan gauge read anywhere between 11mpg-15mpg.
Think I should replace my motor ?
Year: 1997
Tire Size: 295/75/16
Gear Ratio if you know it: 4.88
2WD or 4WD: 4WD
Modifications that affect MPG: Lifted/Amored, Winch
Current highway fuel economy: SHITTY!
Automatic or manual transmission: Manual
4 cyl or 6 cyl: V6
Year: 96
Tire Size: 285/75/16
Gear Ratio if you know it: 4.10*
2WD or 4WD: 4WD
Modifications that affect MPG: 2" Body Lift, Toytec Boss Lift, 1UZ-FE.
Current highway fuel economy: 30!
Automatic or manual transmission: Auto
4 cyl or 6 cyl: 8 ;)
Disclaimer, I've not done a "Best MPG Run" since I re-geared to 4.88s, - I'd imagine its got considerably worse.
But my personal best for a TANK AVERAGE was 30 MPG. I reckon I could get 400 miles to a tank, but that's basically driving at 50-60 for the entire tank, highway, with a warm start straight onto the road.. never actually made the magic 400 for fear of running out/fuel gauge distrust.
Also 1 UK Gallon is 1.2 US Gallon
Average is about 21.
I'm still at 17 mpg, on a dead stock '97 Limited :). That's at 77 mph. Closer to 18 mpg at 74 mph, which I was able to do once thanks to crappy visibility conditions. Can't go any slower on I-5 or I'd get run over by 18 wheelers.
I think all the reported numbers should also include the speed - there is a HUGE difference in mpg between 55 mph and 75 mph.
And of course anything reported by Scangauge, or a single tank of gas, is highly suspect in my book.
97 5 speed
4.30
285/75/16
Fully armored
Storage box
Roof rack
Not sure why you would do that. Make sure you calibrate the Scangauge, otherwise it won't be very accurate (mine has about a 7% adjustment to get it about right).
-Charlie
Year: 1995
Tire Size: 285/75/16 (33's)
Gear Ratio if you know it: 4.30
2WD or 4WD: 4WD
Modifications that affect MPG: 3" suspension lift, 1" body lift, bigger tires, belly armor, sliders, bumpers, winch, roof rack. Lots more weight.
Current highway fuel economy: 15 - 16 mpg at 75 mph, 13 - 14 around town. Sometimes lower when it's cold and there are lots of short trips (10 minutes to work, for example, not great for MPG)
Automatic or manual transmission: Manual trans
2002 2WD Sport Edition
Bone stock
Recently replaced wires and plugs
Getting ~19.5mpg hwy at 70-75 mph
Mileage was ~18.25mpg prior to the plugs and wires. 1mpg is a pretty good increase from some general maintenance.
Year: 2001
Tire Size: 265/70R16
Modifications that affect MPG: stock except removal of the "spoiler"? over the 3rd brake light
32 PSI, fresh 80w-90 in differential
Have NOT cleaned the MAF in forever.
I hear that helps. Will clean mine and report back after next road trip.
{update}
I'm amazed at the impact of cleaning the MAF and driving a bit slower.
Before, I was at 20.5 MPG at 65 MPH.
After cleaning the MAF...
24.2 and 24.9 MPG (2 tanks) Speed: 60-65 MPH
That's equivalent to about 20% lower cost, or paying about $2.40 per gallon if it's at $3.00
These were highway-only miles (no city driving, etc.) Distances were 191 miles and 221 miles, fairly level interstate highway (I-5 in Oregon and Washington, no mountain passes.)
This was calculated by filling the tank and reset the odometer, drive, then dividing miles driven by gallons used to refill the tank. Just to be sure, the pump was made to "click off" 2 or 3 times on the refill. (Don't do this, it could flood & ruin your charcoal canister and turn on your CEL; but that's another story.)
Besides cleaning the MAF, see the other poster's message about wind resistance and increased air density in winter. In general, wind resistance is the square of velocity for objects the size of cars and trucks. In general, this means that doubling the speed increases wind resistance (drag) by 4 times.
http://www.toyota-4runner.org/3rd-gen-t4rs/248374-what-your-highway-mpgs-5.html#post2871670
1200 HP example:
www.physicsforums.com/threads/the-force-of-drag-is-proportional-to-velocity.372972/
How do I prevent the embarrassment of going 65 MPH or less on a freeway? Find a semi 18-wheeler going about the speed that I want, and follow it for 200 miles. Everyone just passes you and the semi. Be very polite. Follow 100-200 feet behind. (This reduces the rock chips, too.) Preferably it's an empty semi, so you can maintain speed going up hills.
Cleaning the MAF - the method below is if your screws are rusted and/or you don't have a stubby or right-angle phillips. Mine was just two small screws and using the special cleaner. If you screw up, it's expensive to replace. (I found the MAF cleaner at Walmart.) Removing the EFI relay for 20 minutes in my 2001 did nothing for resetting my computer (readiness monitors on OBD scanguage were all still OK), so I took the new mileage readings after having driven 2000 miles of city/highway.
Toyota 4Runner Highlander Mass Air Flow Sensor MAF cleaning
Wow, impressive. I got zero improvement after cleaning the MAF (which looked pretty clean to begin with) or pushing a can of BG 44K through the tank :help:
I might try your method and draft an 18 wheeler at 65 mph for 100 miles, just to see :).
I was being sarcastic about “ get a new engine “. lol.
Dammit! I should have known. Needs more armor. See if you can get down to 10.
Its like doing a track day in a car. My record there is under 10 in my Camry... That really sucks with a 14 gallon tank filled with 100 octane.
-Charlie
2001ATL
