what did you do to get better gas mileage?
I have been 'enjoying' my V8 so I'm at 16MPG. I tried so hard to grandma treat the truck and found through a a tank I got just about 20. I've been back to 'enjoying' the V8 though. I have not had a chance to take a long trip yet. Break in mileage like mentioned, is going to be a bit worse.
I'm managing 17.5 MPG around town. I'm 55+ and you guys get in the 20's?!!? Still have not tried it on a long highway run. '07 V6
5 days? Obviously this must be your 1st car. To get a good feel for what your gas mileage is, you need to hand calculate at least 6-12 fill-ups. There are som many variables that affect gas mileage. You could drive the same 400 mile stretch of road at the same speeds getting gas at the same gas stations and STILL get as much as a 4-5 MPG variance each time.
I have an '08 V6. If I can keep it at or under 65 MPH, I can average 23-24 MPG pump-to-pump, all highway, hand calculated. If I'm running errands around town with a lot of short stop-and-go trips, I get 13-14.
:iagree:
Same for me - with the cold weather double check the air pressure in your tires. If it's used, disregard anything about engine break in hurting your mileage - if it's new, you need more time as others have said.
I started buying ethanol free gas. I was averaging close to 16 1/2 mpg running 10% ethanol gas. Now that I have been running ethanol free gas I am averaging close 18 1/2 mpg. This is with my lift and larger tires and about 80% city driving. So go ethanol gas if you can. It does cost more per gallon but works out to still be around 15 cent per mile which is close to the same price per mile as the 10% ethanol gas. Even though it works out to cost the same my truck is running better that before and my idle is nice and smooth unlike while it was running 10% ethanol.
Aaron
I keep my foot off the gas pedal everytime i get a chance. Like if there is a slight downhill, i take my foot off or if i'm coming to a stoplight/sign since i'm gonna stop anyway, i take my foot off and ease on the brakes. I also take blvds, avenues, freeways, (long stretch of roads) to reduce my stop 'n go habitats on side streets. So it also saves my brakes (lifetime), too. Most of the time, i drive 45-55mph on blvds and avenues and 75-85mph on the freeway. I get 17 in town and 20 on the freeway.
To be honest i just got the car last week from the toyota dealership, (certified)
i did fill up the tank and i was basing this off of the mpg thing on the dash. i actually havent finished the tank yet. i will calculate this weekend as i should be done with it soon.
what tire pressure should the front and rears be? Everything is stock.
also the dealership stated that they changed the air filter also.
oh and this is a 2004 4x4 sr5, i based it off the dash reading thing because i thought it was accurate. ill drive the car couple through couple tanks and see.
how many gallons is the full tank on these cars btw. i filled up 20 gallons at the gas station but that was with the tank having a little big more gas in it.
im guessing the tank is 22 gallons?
and i use regular gas (thats what the dealership told me to use.)
ok then filler up. Use your odometer, reset to zero. Don't gas up until you're almost empty (orange gas indicator will light up). Then tell us how many miles have you driven since it was full. Take that and divide it by 22.
okay cool thanks everyone.
and im guessing it is a 22 gallon tank since i have to divide by 22. i really hope im not getting 14 miles per gallon.
Like eskimo said......
MPG = Miles driven since last fillup divided by gallons put in
This is provided you didn't stop and just put in a few dollars worth along the way.
Here's another thing to think about....did you reset the MPG reading when you filled up?
If not, at your next fillup - flip through the "MPG" and "AVG Speed" and push and hold the reset button at each of those. Resetting avg speed won't effect your mpg, but will give you an idea of the type of driving your doing over the course of that tank.
If you bought it used and didn't reset the MPG setting, who knows how long it's been in the 14 range and it'll take forever to get it to move. If it was left idling or anything like that it'll drop like a brick.
Again, like others said - the MPG reading on the display is anywhere from 5-10% off, so manual is really the way to figure what you're getting. But, the display is helpful if you keep that in mind - it does get you in the ballpark.
Just some thoughts as you learn your new 4Runner.
Don't guess. Check the darn Owners Manual. My '08 has a 23 gallon tank. And you don't divide by the # of gallons the tank holds. You divide the miles you've driven by the # of gallons you used. Oy vey...
Tire pressure is somewhat a matter of choice. You can run the recommended pressure listed on the door jamb or you can experiment and find what suits your style of driving. However, for every roughly 10 degree F. ambient temperature change your tire pressure will change about 1 PSI (hence everyone suggest you check it now that your temps are cooler; low tire pressure = worse gas mileage). I usually keep mine at 32-33 PSI.
When calculating your mileage:
Odometer reading (current fill-up) - odometer reading (previous fill-up)/gallons (current fill-up)
Keep a pocket planner in the car and log your odometer reading at each fill-up along with the # of gallons it took to fill up. The planner is also a great place to log any maintenance. Also at fill-up, reset the MPG value on the on-board computer.
I have a ;03 V8 4wd Limited and I get as high as 19.3MPG when driving from Boise to Portland. Just did this over Thanksgiving. If you have the MPG computer like in the '03, you might want to reset the MPG with the reset button and start over. When we got the 4runner used 4 years ago, we noticed the samething and was a little concerned. Once we reset the MPG on the computer, it went up. With the driving I do (8 miles, 2 stop signs, 5 stop lights on state highway), I avg 17MPG and everything is stock.
Hope that helps
Typically the MPG on the display in my 4Runner is 12-13% higher than when manually calculated.
When I tow my trailer, the MPG on the display does go down to around 10% higher than calculated which I always found interesting.
As far as getting better MPG goes, Momentum is your friend. I learned that early on when I first started towing my trailer.
Getting almost 6K lbs of trailer moving and keeping it moving is all about looking far down the road, seeing potential driving situations
well before you reach them and prudent use of the brakes. All that impacts the momentum of a vehicle (and trailer).
The same holds true for just driving the 4Runner. If I look down the road and see a red light or a line of cars that are stopped I will
take my foot off the gas and let my momentum carry the 4Runner forward then gently apply the brakes as needed.
I have already paid for that momentum so to speak so why not use it?
Continuing on the gas then jamming on the brakes to stop at the last minute wastes momentum, gas and brakes.
Steady acceleration from a stop instead of stomping on the gas and drag racing also helps MPG.
Bottom line, a person's driving style and how they react to different driving situations can have an impact on the MPG they can achieve.
I've heard some people say that theirs seems to be 15-20% off. Mine is usually right around 10%. 22.5 on the display will compute out to 20-20.5 actual.
About the same here. I hand-calculate every fill-up and I also record the on-board MPG value before resetting so I can compare. My on-board is usually about 2 MPG conservative; sometimes more, sometimes less.
Cpn2mss
