I did a circle, started by wanting to do a dual battery setup. Decided to run one large deep cycle battery. Tested dc voltage it was low but it was sitting for a while. Got it all installed and charged, truck fired like a champ! 4hrs later not the story, click, click, click. 10.3vdc and dropping. After doing some tests, she is done. So I put the old battery back in :/
5aad2df06442e2c67f0f8eeb0430e351.jpg~original
Old
C9CB06A9-539E-4052-98B3-C461D7BE83DA.jpg~original
Also cut steel for cb antenna, and rear facing led light. And cut steel for ditch lights. Lastly some protection for the lower links
59533015327a9f4a23aa8bad1cad8839.jpg~original
c14b58932391c251320a48143d8e3edf.jpg~original
A7D1D8C4-BF21-4EF6-BFA4-76A9567FE24E.jpg~original
All in all, not a complete loss of a day.
finally decided which grease to use in which driveshaft joint.
pulled slip yokes from front and rear shafts, cleaned 'em out all spic-n-span, seals look good, greased, assembled, pumped new grease in. Front took @40 pumps, rear @30ish I think, but I forgot and stopped counting.
Pumped new grease into other fittings and purged all the old stuff.
removed seat belt assemblies and power washed webbing at car wash. Retracting better but still kinda sluggish. Wanna figure out how to wind the spring 2-3 more turns. the spring almost ka-boinged an escape from its housing and I wrangled it into submission. So close.
not trying to be a dbag know-it-all, but my experience and all of what I've read about this whole shimmy/vibration/wobble at xxx mph is due to out of balance tires, which will never be properly balanced without the Hunter GSP 9700 with Lug Centric adapter and Road Force balance.
You can get the balanced over and over and over, they can add 3 Lbs of weights, whatever. It won't work because our wheels are Lug Centric.
This is a known issue that many many dealerships and tire places are not aware of and dismiss as untrue.
Confirm the tech knows what he/she is doing. Many don't know how to use the machine properly.
I thought our wheels were hub centric?
Thanks for the info! :) Not taking it like you are trying to be anyway. I appreciate the information.
Well today I did something I love to do....Redo something i've already done and that was my cb radio.I redid the grounding on it and reinstalled it but I finally tuned it :hatsoff: so im happy up next buy a new power steering pump.
Oooo I almost forgot I took apart dash and center console to figure out a simple light bubble was blown in my gear shifter.....Always check the simple stuff first.
....Always check the simple stuff first.[/QUOTE]
That's why i own a Toyota don't broke often and alway's simple to fix...:roadkill:
Today I bought a Marlin Crawler 1200 clutch kit from a fellow member. Also on Friday I replaced my 285 KM2s with 265s Duratracs and gave her a quick wash.
417d14dd-08d7-4266-9081-02409a05ac62_zpsd2a09624.jpg~original
utkrstam
