I have OME's on my Tacoma, and Bil's on my 4Runner. Totally LOVE the Bilsteins.
And as my Contribution. My 4Runner is done for now, and off for an alignment in the morning. The past 3 weeks have been a bunch of work.
Nice! Yup I have bilsteins on my 06 Tacoma and love the way they ride. This setup is a little different seeing the springs are new and its 4 coils not coils and leafs like the Tacoma so I'm curious to see the difference if any.
Finally found a clutch start cancel switch for my 98 4runner; there are plenty out there for 96-97 but they changed a few things for the 98 model.
One thing is that I thought it would stay in a clutch start cancel mode after you turn off the engine but it turns out you have to push it every time...seems like a good safety feature though.
Last week got a screeching noise from the front end so checked things and the steering rack bushings were shot so changed Sunday ....the noise is still there so I went to the shop we go to and its my right lower ball joint soooo went and bought a Moog ball joint and changing it Friday .....oooo and it was the original one so that's awesome lol...
Read up a couple posts in this thread and do a little research on the Moog ball joints before you put them on your truck. You should only use OEM on the LBJs, and even then the OEMs should be replaced every 100k or when there is a visible issue. Anything is else is just a disaster waiting to happen.
How did you mount the Yaesu? I just got an Icom IC-2730A, and I can't quite decide how to mount the control head.
I initially used Velcro on the little lip part of the single din, but when in direct sunlight it fell right off, so i mounted it with the same method down near the shifter with 2 strips and it is now solid and still easy to see.
I got my 97 4wd SR5 ready for sale (desert dune color)
it has 195k miles
NEW
Radiator
toyota timing belt
toyota water pump
toyota coolant
toyota t-stat
O'riley's T-belt tensioner pulley
O'riley's fan clutch
toyota U&L rad hoses
Needs
rear axle seals
rear brake cyl's
rear brake shoes
front pas spindle bearing replaced
Rust hole in roof patched/fixed
Car fax shows it was in flagstaff for 20k miles, before that southern CA.
the rust baffles me, but I guess anything is possible.:shrug:
I'll be asking 5500, much less than what I bought it for. think it will go?
Guys on here have had moogs fail in 2 months. OEM are only around $88 each which will save you hundreds if not thousands if the front wheel falls off.
Finally installed my Hilux 167 snorkel. Thanks to all those who've already done the install, your advice and tips were priceless.
This way last weekend but still new stuff.
LED switchbacks in for the blinkers and Fatmat on the hood.
Well not today, but this past Saturday. Replaced the power brake booster. It failed without warning yikes!!. Wasn't too bad of a job, probably do it in a quarter of the time next time. Took me 4 hours.
Ambrose67
