Went to the Knoxville Cars and Coffee with a friend and his 4Runner. Snapped a quick smart phone shot.
On a side note; one of my retro'd headlights fogged up for the first time this morning (as you can see in the picture)... If it happens again I'll have to pull it and try to find the breach :(
IMAG1669_zpsx5lrraaf.jpg~original
IMAG1668_zpsfp3yxh3y.jpg~original
I think this tread is my favorite tread in the forum. More down to earth, and less "LOOK AT MY PRETTY RIMS!!!". Anywho, I worked a little on my home made roof rack today. Hope to finish it Thursday or friday.
edit: ^^ sorry about the skid
The previous owner had carried bikes in the back of my runner, and the handle bars had dragged across the roof making it all hairy and terrible looking. I took a cheap single blade razor and broke off the plastic guard piece in front of the blade and used it to shave my roof. It looks great now.
Interesting - I should give that a try. I'll bet if I put both seats down I could get my bike in there without hitting the ceiling. However my laziness knows no bounds.
My steering wheel controls (ASWC) went off the reservation. I couldn't get it reprogrammed correctly. I forgot to pop the OEM stereo back in to see if everything was working without the ASWC. I also forgot to install my SiriusXM module. Overall, a very disappointing morning.
I drove on a trail that was much more challenging than anything I've done so far. I think it was about at the limit of my stock 4th gen.
The trail was narrow and steep with nowhere to pass or turn around, and there were only a small number of possible lines through any section. I hit the front skid plate and gas tank skid plate on some large rocks in a few spots but I didn't seem to dent them. I bent a bracket that holds up the running board, but it should be easy to bend back. And I got plenty of trail pinstripes that I'll have to buff out.
I was with a friend in a lifted Tacoma. He has a rear e-locker, a few inches of lift, and A/T tires. I just have LTX MS2 tires, stock size, stock height. His Tacoma didn't seem to have ATRAC, so he would just spin wheels. But ATRAC on mine was awesome! There were several sections where my 4runner had an easier time getting over stuff than the Tacoma, despite me having smaller tires optimized more for highway driving.
There were a few spots where one or more tires had to climb steep roots or rocks. I just gave it a bit of gas and let ATRAC push me over the obstacle. There were a few where the wheels didn't spin at all, despite the Tacoma having trouble. Towards the end there was a section of snow. I hit it with some speed, but not far into it I felt like I was slowing down and about to sink in. But ATRAC kicked in as I gave it a bit more gas, and with more pounding on the brakes than I've ever heard I made it the rest of the way up at a steady speed!
I had trouble in a couple spots. When I was stopped with one or more wheels on something but not all the way over I would start to roll back fast if I let off the brake. HAC is useless and doesn't activate fast enough (maybe not at all if your foot is still lightly on the brake?) With one foot on the brake I gave it some gas, but one or two of the wheels would just spin freely as I let off the brake and gave it more gas, and ATRAC didn't activate (or not quickly enough, anyway). Maybe using the brakes cancels ATRAC? I got over those sections by backing up off the obstacle and trying again from just below it.
I realized after that some parts would have been a lot easier if we had aired down our tires. Rookie mistake! But neither of us has a compressor, and I'd prefer not to have to air back up with the bike pump I carry. (it's good for small adjustments)
It ended up being a fun experience, but there were a few sections where I was worried we wouldn't be able to get through.
moral: DO YOUR HOMEWORK
Headed to DC this weekend and noticed my overflow coolant tank low. I never dealt with the radiator so I got some parts (bolts for removing coils, they were very rusty) and one gallon of coolant. Guy at the parts department told me I needed the LLC (red stuff). Because I didn't know, I took it. Then I remembered the "pink stuff" and got confused. I never opened the LLC jug. Thank GOD I didn't! Anyway, long story short, my 2005 takes the pink stuff. Toyota changed everything to PINK (SLLC) after 2004. Whatta dumbass!!!!!
Also bought a bucket (with marks showing how full it it......... I got a 3 gallon bucket........... which is ABOUT the capacity of the 1GRFE coolant system (2.6 gallons.......... correct me if I'm wrong). Also picked up some clear plastic 3/8 tubing. Why? I plan on draining the block too and don't want to make a mess when its draining.......... hey , may as well, right?
Coolant change for 1GR-FE - Toyota Nation Forum : Toyota Car and Truck Forums
yes worth draining your side block ports as well. Even when doing all this keep in mind you're not getting ALL the coolant exchanged but it's close enough in my opinion if done every 50K or so... the dealer can exchange all the fluid for you but costs $200 or so depending on the dealer.
My PLAN today was to put my skids back on. But that went to hell in a hand basket when I realized that my front diff is leaking, and I have some sort of Oil leak. F.M.L.
I still had a lot of residual mud underneath so I washed it off, and let it all dry so I could find the source of my diff leak. It appears to be the Drivers CV seal. Which sucks, cause I need to replace the passenger driveshaft... Looks like i'm gonna be reading all the "how to replace your CV's" threads.
Still pretty bummed about the leak though. I beat on my truck pretty hard, but only because I think it can take it. Maybe not. :/
Replacing the cv's is pretty easy, just time consuming, go with cvj axles and you won't have to worry about it for a LONG time. The seals however, I've heard are a pain, I just left mine because they looked good, 5,000k later still good!
Fixed clunky sway bar bushings. I cannot believe the difference this made. I should have done this when I bought the truck. feels much better and SO much quieter its actually weird.
BillM777
