Over the holiday I....
Restored my LCAs- removed rust, primed, painted, new ball joints, new Whiteline poly bushings, new Moog greasable cam bolts.
Installed new Icon UCA w/ poly bushings.
New CV axle
New spark plugs
new front diff, rear diff, and x-case oil.
Extended the rear diff breather
Did the VSC off mod with factory switch
Tightened up my Dr. window (track bolts were lose)
Installed speed bleeders
Flushed power steering fluid
:banana:
Terminate warning chime
silver 2000 SR5 2WD 175K
Try to Find and kill dingdong bell that sounds when door is open and key is accs position.
No success
Steve
Went for these from RockAuto, $111 shipped.
POWER STOP JBR971XPR Extreme Performance Drilled and Slotted
POWER STOP 17606 Z17 EVOLUTION PLUS w/Hardware Kits
Hopefully my calipers are ok.
So what if my truck suddenly starts running rough 5-10 minutes into my drive? Dash warning lights flashed briefly and now it's running "lumpy."
Was dark when my wife got home with it but temp was fine, oil and coolant levels where fine.
Need to take a look tomorrow when it's light out but don't know where to start.
2005 V6, 164k miles.
Ordered the parts for 03 -> 06 headlight conversion as part of my satoshi grille upgrade. Pictures will happen when I have time to put the grille together.
Sport Headlamps
Bumper Filler Pieces
OPT7 LED Bulbs
9005 -> H11 adapter harness
I ran those. Only issue I had was dirt and mud while offroading tore them up quick. On the street they stop you super fast!
Replaced my front calipers today... Again... Nobody had any 5th Gen calipers avaliable. Replaced with duralast and now have a lifetime warranty though!
uploadfromtaptalk1452130374734.jpguploadfromtaptalk1452130382014.jpguploadfromtaptalk1452130389470.jpg
While swapping these out I found out my drivers side shock is leaking oil from the top and it looks like it is broken. Great... Contacted Down South Motorsports to see if it's under warranty.
alexaturner
