Got my wheels this week and put them on. 17x9 -12mm
Changed the Oil today, which should of been easy.. but the bolt holes for the front skid stopped grabbing the bolts enough to be safe.. so I had to get a tap and make bigger holes and put bigger stainless hardware in.. Probably better off now.. but its done..
Also, first oil change with fumoto drain valve.. I should have got that a long time ago..
What size did you tap?
Installed a Tepui awning. Really happy how it turned out and how easy it was to mount.
Sent from my ONE A2005 using Tapatalk
They're 265/70/17 Falken Wildpeak AT3W
That the LT version? Tread pattern looks slightly different than my P-rated ones in the same size
EDIT: Nvm, was looking at a different post =D Excellent choice in tires, hope you like them as much as I like mine
Front brakes. You know the drill.
Not entirely happy with pedal feel but stops OK so I'll bleed again later when I have some time.
Such a tease. Where's the deployed pic?!
I've been looking at the arb myself. I actually really like the ezi awn, but the price point is significantly more.
I'll post a pic of it setup tomorrow. Had my kid's school orientation tonight and almost forgot, so I haven't had the chance to open it up yet.
Looks great.
Any thoughts on blacking out the headlight housings and spraying the running boards black. Then the whole truck is blacked out and a pain in the ass to keep clean. Lol
Looks great.
I've thought about the headlights, but absolutely hate messing with the housings, so it's unlikely unless I start getting moisture in there or something.
And I've actually rattle canned the running boards black, but they get a lot of abuse, so they end up looking grey pretty quick. I need to spray them again. I'll probably do it when I repaint my shovel.
And my 4runner isn't all black. It's actually dark grey. Picture is a little older, but you can see the colors better.
IMG_20160418_0906452.jpg~original
A couple pictures of the awning setup. Sets up and tears down incredibly fast. Less than 10 min to set up, take pictures and put it away.
Found some more unposted land to explore. This power line right of way and at the bottom of the hill an old railway grade that's been defunct for about 50 years.
Putting these bad boys on. They just showed up.
Super pumped. Sending my Original Icons back for rebuild.
