What do I have to do to get these rims to fit?
whoops, good catch gaterose, i didnt even look at the bolt pattern. looks like they don't make an 18" in 6x5.5.
on that note, i would advise against adapters.
So would they just fit as long as I took the spidertrax off? Would my wheels not stick out as far anymore?
If you find some with the right lug diameter that is somewhat correct. Because of the increased width they would stick out as far, but also stick in further.
But none of that matters if they're not 6x139.7mm. There may be someone who makes a 6x135mm to 139.7mm adapter but I've never heard of anyone and as STAYGOLD says I would be a bit leary of it.
easiest thing to do is buy a Ford F150. thats pretty much the only truck that is 6x135mm bolt pattern.
As long as you find the right bolt pattern, they'll fit fine depending on your tire size.
with a 0 offset they roughly sit flush with the outside of the fender, which is what your spidertrax are accomplishing for you. additionally, with them being wider they will protrude inward and outward further, as gaterose stated, which could cause rubbing issues but its hard to say.
i would see if your local discount tire or the like carries pro comp (don't think discount does) or something in the same size, width, backspacing etc and have them throw one on to get a better idea. 9" is a whole 1.5" larger than oem so factor in 3/4" on either side of the hub. you may need the spidertrax to clear them on the inside of the wheel, which in turn is going to put your rim pretty far "out."
It would probably be cheaper if you just found similar wheels with the correct bolt pattern. They do make those with the correct bolt pattern but only in 17x8 and 17x9.
So I need 139.7 to 135mm?
You listed the correct ones, but those will make your wheels stick out very far.
Edit - Wait, re-read, you and gaterose were right. My mind is a clusterf- right now. But still, they will make your wheels stick out far.
How far are we talking? I guess what my question is, what will I have ot get for those rims to fit and give me around the same offset that spidertrax gives me now. I like the stance now, just dont wanna lose that stance by getting new rims and those are pretty much the only ones i like.
Its basically putting 1.5" spacers on those wheels. I don't know how to do the calculations, so someone else can have a go at it.
or go with these, if they're not out the waz expensive. Fuel Offroad Hostage. Available for us!
youngrk
