What does your interior look like?
TejasRunner01
Are you proud of the hard work you have put into your rig's interior? Do you have gadgets or modifications that you want to show off? Post them here!
Got the 99-02 console box, dial type HVAC controls out of a 98, Steering wheel and spiral cable from a 99, window master switch from a 99. Looking for some 00-02 front seats, in my 97 SR5
Looks great. I also have a 97. Is there an easy way to just change out the hvac controls to the knobs instead of the sliders in my 97? I hate the sliding knobs, would like the circular controls but don't want to do it if the install is a nightmare. Thanks for any help
It's not terrible, one of the cable has a different end, which is not the end of the world, you will need a wire diagram for a 98, the fan switch and A/C wires/ connectors are the same, as with colors but in different pin locations. So I used a small 3/16 rivet and pulled the pin out, cut it down to fit exactly were i needed it. And then for the wiring I was able to look at diagrams so I could de pin and put wires where they needed to go, I think there was only one wire for the blower that was a different color.
clean that thing up you filthy beast!
It has been, that was taken right after the mods. I would have cleaned it better for the pic, but figured there aren't enough real life pics on the net. I was also lifting the center panel for my back window and ECT, until about a month ago.
Yes I'm proud of my carpet mod and accessory cables.
I have a 2000 so I like the interior mostly. I did swap out all the wood grain stuff for SR5 flat back parts because I hate the fake wood grain. flat black no glare, simple me.
I also just picked up a 1997 as a winter beater and a challenge to keep it running for as long as possible. When I first got it... kids had been riding around in it. I pulled the seats out and found several piles of skittles, french fries, princess Ariel hair scrunchies, spilled milk, enough coffee spills for a latte.
you don't really realize how disgusting things can get until you clean it out.
There IS real wood in there, although just a thin veneer. I was able to peel off that thick awful clear plastic overlay, and then sand, restain and polyurethane the wood and I like how it came out.
_qyzWuSap6Jgw2YyB_1S-p2T2FAnr4CPm9_fjLG75mZXsl4qeMKwU3SIjwuTxCe6ea4MdtQjM4bbCxOjdBs0J171xBfB-QX1y38IAAsapcl8Ia-D5Ip2URyAI03rTwLAqbaQBXO6iOVmuyq4p7ludidcC6wh3Sv7oy-liUwrMIfXcmJNDw6z3jE1ByzMZJYEtSv4Nty89hMlE7ROfZMKzFb7O3jsRxIxJEdoC6lvDyAMcnH8vAXRJB6B3X8kQLMPx2EFmsWOUR1BCP1m5ogPlyXHADW6IrNq-p4RlSK-4Qa2Z2SsQAGamqa7_wWNGYlFbJBz5iAooEJiLFus0egvEagcvhkRx2ECr2Kczi2doXzM3MaAc5qqSYZSBnmpXFiAW-jrqxXhFh2LUxD6Ph5L8CJ7SEEoaeiuohU324h070SCUf6TPqrs3ZKvE9qgHCIe-hWhrzK5yORmcb-kwfE4TFpcMgZO74B46Qdl9N12LKE4stdEjlDXBCuffvQebKLmhzpkCL7C7SLB7HTHEf101Y_n3tp6vt4-_Ja9YZvSoaFSUgsYCce-OTu9nVU2bcDWCrmK9VJW8lNIH_D1Ok_HXpeR5jDJmD8ZpqoZ7QWMr43Qaz3yDtQ31fQ6KmmJFmNNs06CQE7dNmeYhJb7br5m2kcN=w1305-h978-no
Only helped me negotiate!
I am now only because the PO had dogs and they SHREDDED the back leather seat. Also the smell of wet dog was so embedded into the material and foam I made sure I had some second hand sr5 seats to swap them out with. Sucks cause I really wanted the heated aspect of it but the trade off was either wet dog smell or suede sr5 seats that just needed a good upholstery cleaning. So off to the curb the leather seats went! I took it all the way down to the floorboards. I still haven't taken any photos of the sr5 seats!
Cheers to keeping these rigs on the road!
Just picked up my 2000 4WD SR5 sport 3 weeks ago, noticed it has a Rear Diff lock switch which is pretty awesome! Interior is pretty clean and everything suprisingly for its age is fully functional...only thing I added are some new OEM Toyota 4Runner floor mats.
044runner4
