what gear ratio
smkd13
ok so i have a DD that will see trails. will be running a 33 to 34 in tire and wondering if i should go with a 4.56 or a 4.88?
Stock is 4.10 or 4.30 depending on year and elocker. So going to a 4.56 wouldn't be worth the price tag. My vote would be for 4.88 or 5.29
Oh yeah sorry it would be a 2001 with a 3.4 and I believe a340 and no locker. Will be using an arb or zip in the rear. The stock tire on the tag is a 225.
I have 265/75r16 right now and it seems sluggish as compared to where it should be so I am upping to a better ratio. So what would the adverse side of going 5.29 be?
If I'm not mistaken...2001 without a locker, you should have 4:10's from the factory. I'm in the same boat...I have 4:10's and I just put on a set of 33's. I'm been trying to decide what gears to go with also. At 65 mph, I'm only turning 2000-2050 rpm's. I'm thinking 4:88's will be good. I don't to low cause this is my DD too. I'm trying to find one of those charts that shows you which gears to run with what tires and at what rpm's. If I find it, I'll try and post it for you...
I am right about at 2100 at 65 so that would make sense. I will probably go with 4.88. And that would be awesome and definitely helpful.
Anyone heard anything about zip lockers?
Hi, actually im doing the same. I have already decided for 4.88 by suggestion from trail-gear.com but im afraid of get the wrong parts (10000 km shipping), for the front diff overall.
I have 1KZ-TE engine, don´t know about transmission.
A friend told me the original gear its 4.1 for sure.
Can you help me?
What year? And you might check out ringpinion.com it is selectable by axle and as well inchworm (google it) is another good reference.
Thanks a lot, its a 1998 4runner, here in Argentina also called SW4 and the most popular engine was the 3.0 Tdi. Rear Diff its ARB and in the front sure it´s the 7.5" you told me. So i expect dont make a mistake, there shouldnt be such differents from yours.
Thanks for the links.
premiumusedautoparts
