What hosing should I get for the wiper fluid line
Pyral
Member
I found out that the line that provides wiper fluid to the rear window sprayer is cracked where it runs under the passenger side door sill. Its leaked everywhere, probably done in by the high antifreeze ratio I use in the winter.
Anyone know the hose diameter that Toyota used? And should I worry about what sort of plastic its made out of?
Cut a small section off and take it into your local auto parts store to find the correct size. Any rubber hose will be fine.
The inner diameter is the important measurement on the replacement hose. Recently I looked locally for replacement hose for the washer lines under the hood. There was no exact match for the hose, but I found a thicker hose that had a very close I.D. and used that. Hopefully the auto parts stores near you have a better selection than the ones near me.
How hard is it to access the length of the line?
I know the hose runs under the front and rear passenger door sills, but I haven't seen how it connects to the spray nozzle or the reservoir. Should I just replace the damaged section?
Philthyphilthy
